I tried to make a WOL working on a HP Z600 workstation where Xubuntu 16.04 is installed.
WOL is enabled in the BIOS and ethool shows it as enabled :
$ sudo ethtool enp1s0 | grep Wake
Supports Wake-on: g
Wake-on: g
I checked that Magic Package is received on the workstation sending it from another computer on the same network by looking:
$ wakeonlan 1a:2b:3c:4d:5e:6f # from a laptop
$ sudo tcpdump -i enp1s0 port 9 # from the workstation I want to woke up
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp1s0, link-type EN10MB (Ethernet), capture size 262144 bytes
11:05:44.719516 IP port0129.domain.net.58672 > 255.255.255.255.discard: UDP, length 102
I also tried to send the magic package from port 7 with out without using a broadcast IP. In all the case when I have the workstation running I received the magic package.
I also tried to send the magic package with a reverse MAC address as pointed by How to enable Wake On Lan (WOL) in Ubuntu 16.04
Instead of clicking on the "shutdown button", I tried to shut-down the workstation with:
$ sudo shutdown -h now # and also -P
In all my test when I send the magic package nothing happen to the workstation.
NIC led are also blinking when the workstation is down.
Any clue/idea to unlock the situation?
