34
I have a pretty beefy graphics card with 4GB of memory etc. But I can see the YouTube videos stutter sometimes and have a poor framerate (although none get dropped).
I feel like with a decent graphics card this shouldn't happen. Is there a way to make sure the gpu I have works properly?
Edit: I'm confident, that the internet connection is not the problem, since the "video stats for nerds" of the videos I am looking at show 0 dropped frames and perfect buffer health.
Edit2: XUbuntu 16.04
$ lshw
*-display
             Beschreibung: VGA compatible controller
             Produkt: NVIDIA Corporation
             Hersteller: NVIDIA Corporation
             Physische ID: 0
             Bus-Informationen: pci@0000:65:00.0
             Version: a1
             Breite: 64 bits
             Takt: 33MHz
             Fähigkeiten: pm msi pciexpress vga_controller bus_master cap_list rom
             Konfiguration: driver=nouveau latency=0
             Ressourcen: irq:43 memory:d7000000-d7ffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:b000(Größe=128) memory:c0000-dffff
Minix
  • 1,083
Benchmark your GPU
1. Mesa Utils
Install the following package:
sudo apt-get install mesa-utils
And then start a benchmark test from the commandline
glxgears
With a modern GPU you should achieve frame rates (FPS = Frames per second) of more than 5.000. The is limited to the refresh rate and resolution of the monitor!
Invoking glxgears with vblank_mode=0 tells the graphic card to ignore the refresh rate of your monitor and just try to reach the maximux fps it's capable off.
vblank_mode=0 glxgears
If vblank_mode=0 doesn't work then try __GL_SYNC_TO_VBLANK=0 instead.
2. Open GL
Run the OpenGL benchmark test with
sudo apt-get install glmark2
and run the test with
glmark2 --fullscreen --show-all-options
The score is adapted for modern and fast GPUs. Note that the fps score depends on the resolution you set during the test!
Afterwards the result can be compared on e.g. this benchmark page.
3. Benchmark Unigine
A 3rd party benchmark tool is Valley. The free basic edition is nice to test your hardware. There are different scenarios you can choose. I recommend the valley benchmark test. Download it and change the execute permission using
chmod +x Unigine_Valley-1.0.run
and run the installation (no root permission necessary)
./Unigine_Valley-1.0.run
Start the benchmark engine with
cd ./Unigine_Valley-1.0 && ./valley &
Don't forget to click on the benchmark widget on the top left corner.
Youtube Problems
The most common problem with youtube videos is the lack of a fast internet connection.
S. C.
  • 105
abu_bua
  • 11,313
Visual inspection when running the real application(s)
Play some video with a 'a lot of motion' in it and see with your own eyes, if the quality is good (no tearing, no lagging, no stuttering etc). Run your other programs (if any) that need good performance of the graphics.
Check also the CPU load during the test (for example with htop).
If you are satisfied, fine :-)
Otherwise look for alternatives,
  • tweak the application program (video player or other program)
  • a lighter application program,
  • lower resolution of the screen
  • a better graphics driver
  • another desktop environment with a lighter footprint (LXDE of Lubuntu and XFCE of Xubuntu are lighter than standard Ubuntu)
  • another graphics card
  • another CPU
sudodus
  • 47,684
