This is my situation:
I had Acer E15 with win10 on an SSD and secondary empty HDD. I replaced the HDD with another SSD and re-installed win10 on the new SSD. Then I tried installing Ubuntu 18.04 on the original SSD to have dual boot. I followed this: Dual Boot Windows 10 and Linux Ubuntu on Separate Hard Drives
While doing the partitions I had an existing EFI partition on the original SSD which had label like "windows boot loader". I deleted that one thinking linux EFI would be good enough for the Grub menu to show and identifying both OS. It didn't work out and got the "no bootable device" message. I did re-install linux again but same problem. I did disable safe boot through installs. I used this to fix the no bootable device thing: https://itsfoss.com/no-bootable-device-found-ubuntu/ but still no grub menu. I updated grub as well and still don't have the dual boot. How can I do that? Is it possible at all at this point to have dual boot of the existing win10 and ubuntu?
embi
Although by EFI spec. the only requirement for the EFI partition is that it be formatted FAT, specific hardware may have added additional requirements for windows, such as which partition it is, or that there must be a recovery partition, etc.
Assuming both SSDs are internal, This is what I'd do:
Be sure, the hardware is set to EFI mode only, and secure boot is off.
First, Install Windows to the first SSD, and be sure it boots. Then turn off Fast start up in windows.
Next, Install Ubuntu. When partitioning select "Something Else" to manually partition. Be sure that Ubuntu has selected the EFI partition on the first drive (the one Windows made), and that it has not selected to make a new one on the second drive. Create your Ubuntu partitions on your second drive. and install it.
ravery
  • 6,924
