When I run the command sudo bash or bash --version I get the following error:
bash: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version 'Qt_5.10' not found (required by bash)
The output of ldd is as follows:
$ ldd `which bash`
/usr/bin/bash: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version Qt_5.10' not found (required by /usr/bin/bash)
    linux-vdso.so.1 (0x00007ffc3e4e6000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f041be89000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f041bc85000)
    libQt5Widgets.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Widgets.so.5 (0x00007f041b43e000)
    libQt5Gui.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Gui.so.5 (0x00007f041acd5000)
    libQt5Network.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Network.so.5 (0x00007f041a949000)
    libQt5Core.so.5 => /usr/lib/x86_64-linux-gnu/libQt5Core.so.5 (0x00007f041a1fe000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f0419fdf000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f0419c51000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f04198b3000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f041969b000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f04192aa000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f041c0a6000)
    libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007f041901e000)
    libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007f0418dec000)
    libharfbuzz.so.0 => /usr/lib/x86_64-linux-gnu/libharfbuzz.so.0 (0x00007f0418b4e000)
    libicui18n.so.60 => /usr/lib/x86_64-linux-gnu/libicui18n.so.60 (0x00007f04186ad000)
    libicuuc.so.60 => /usr/lib/x86_64-linux-gnu/libicuuc.so.60 (0x00007f04182f6000)
    libdouble-conversion.so.1 => /usr/lib/x86_64-linux-gnu/libdouble-conversion.so.1 (0x00007f04180e5000)
    libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f0417dcf000)
    libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f0417b9e000)
    libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f04178e8000)
    libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007f0417634000)
    libgraphite2.so.3 => /usr/lib/x86_64-linux-gnu/libgraphite2.so.3 (0x00007f0417407000)
    libicudata.so.60 => /usr/lib/x86_64-linux-gnu/libicudata.so.60 (0x00007f041585e000)
    libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f04155ec000)
    libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f04152b3000)
    libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f041508b000)
    libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f0414e87000)
    libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f0414c81000)
    libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f0414a6c000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f0414864000)
The output of which bash is:
/usr/bin/bash
Prior I tried to reinstall ruby as a bundle needed version 2.2.8 and i had ruby 2.5.RVM was not working fine so when i reinstalled ruby after that these error started occuring.
dessert
  • 40,956
Remove all your PPAs and/or third party packages and try again. This is not a standard Ubuntu package.
The normal bash command is in /bin/bash. You should be able to run it if you call it with the full path. The package in question, /usr/bin/bash is something you installed, perhaps by mistake, and it is taking precedence for the which command, because /usr/bin appears in $PATH before /bin.
You can circumvent the issue by changing your PATH variable such that it lists /bin before /usr/bin.
