Can I copy *.png files without change subfolders address and name?
Example: Copy /photo to /pic converting /photo/2017/hello.png to /pic/2017/hello.png.
dessert
  • 40,956
First create the directory you want to copy to:
mkdir -p pic/2017
Then copy over the files. Normally one would just need cp:
cp photo/2017/*.png pic/2017/
As you mentioned there are too many files and you probably receive an “Argument list too long” error, we’ll use printf and xargs to run cp as often as necessary:
printf "%s\0" photo/2017/*.png | xargs -0 cp -t pic/2017/
You can also use mcp from the mmv packageInstall mmv in the following way:
mcp -n "photo/2017/*.png" pic/2017/
-n let’s mcp only list the changes, remove it to actually perform the copying. Note the quoted asterisk: It’s not evaluated by the shell, but rather by mcp.
dessert
  • 40,956
What you want is to copy the directory recursively, so, you should do:
cp -a /photo /pic
This will copy all files and directories recursively and preserves file metadata.
If /photo has files that are not png files that you do not want to copy, you can do this after doing the above command:
find /pic -not -iname '*.png' -type f -print0 | xargs --no-run-if-empty -0 rm
double-beep
  • 195
  • 13
crass
  • 495
