I followed the 'Debian-based Linux distributions' guide on the VirtualBox website.
After sudo apt install virtualbox-5.2 I got the error:
vboxdrv.sh: failed: modprobe vboxdrv failed. Please use 'dmesg' to find out why.
There were problems setting up VirtualBox. To re-start the set-up process, run
/sbin/vboxconfig
as root.
dmesg: Loading of unsigned modules is restricted; see man kernel_lockdown.7.
How can I fix this?
I read something about secureboot but I don't want to disable it.
Do I have to sign the VirtualBox module (how? add custom sign key?) or is there another way?
I'm running Kubuntu 18.04 Kernel 4.15.0-23-generic.
EDIT
After following this guide https://stegard.net/2016/10/virtualbox-secure-boot-ubuntu-fail/ and executing sudo modprobe vboxdrv I got the error modprobe: ERROR: could not insert 'vboxdrv': Required key not available. With modinfo vboxdrv I see:
filename: /lib/modules/4.15.0-23-generic/misc/vboxdrv.ko
version: 5.2.12 r122591 (0x00290001)
license: GPL
description: Oracle VM VirtualBox Support Driver
author: Oracle Corporation
srcversion: 63368184ED096B3022FD087
depends:
retpoline: Y
vermagic: 4.15.0-23-generic SMP mod_unload
signat: PKCS#7
signer:
sig_key:
sig_hashalgo: md4
So it looks like it's not signed right? Whats wrong with this? I tried to sign it manually with /usr/src/linux-headers-4.15.0-23-generic/scripts/sign-file sha256 ./MOK.priv ./MOK.der /lib/modules/4.15.0-23-generic/misc/vboxdrv.ko with the same result.
