When I remove mysql 8.0/mysql 5.7 using this command:
apt-get --purge -y remove mysql*
it also removes exim4-daemon-heavy package. As far as I know exim is not dependent on mysql. So why does it removes exim?
I get the following log on mysql removal:-
The following packages will be REMOVED:
exim4-daemon-heavy* libmysqlclient18* mysql-common* mysql-community-client-core* mysql-community-server-core*
I don't want exim4-daemon-heavy to be removed. How can we achieve this?
means "Remove any package whose name contains mysq (mysq followed by zero or more l). This includes the MySQL client libs that are needed by exim4-daemon-heavy.
Use
apt-get --purge -y remove 'mysql.*server'
to only remove the MySQL server packages.
