I'm trying to build Rhythmbox in order to fix a bug, but am running into problems doing so.
I downloaded the source using sudo apt-get source rhythmbox afterwhich I ran configure with the argument --prefix=/home/notgary/rhythmbox/build in order to keep the compiled binary from messing up my existing system. After running make and make install, which successfully placed a binary at /home/notgary/rhythmbox/build/bin/rhythmbox, I tried to run the program and got the output that can be seen below.
I've got little experience with building Linux programs from source so am at a loss to figure out why this is happening. Does anyone know how I can get a compiled binary of Rhythmbox (or any other app from the repositories for that matter) up and running?
(rhythmbox:27863): GLib-GIO-CRITICAL **: Settings schema 'org.gnome.rhythmbox' is not installed
(rhythmbox:27863): GLib-GIO-CRITICAL **: Settings schema 'org.gnome.rhythmbox.rhythmdb' is not installed
(rhythmbox:27863): GLib-GIO-CRITICAL **: Settings schema 'org.gnome.rhythmbox.podcast' is not installed
(rhythmbox:27863): GLib-GIO-CRITICAL **: g_settings_get_key_info: assertion `settings->priv->schema != NULL' failed
(rhythmbox:27863): GLib-GIO-CRITICAL **: Settings schema 'org.gnome.rhythmbox.player' is not installed
(rhythmbox:27863): GLib-CRITICAL **: g_variant_get_type: assertion `value != NULL' failed
(rhythmbox:27863): GLib-CRITICAL **: g_variant_type_is_subtype_of: assertion `g_variant_type_check (type)' failed
(rhythmbox:27863): GLib-CRITICAL **: g_variant_get_boolean: assertion `g_variant_is_of_type (value, G_VARIANT_TYPE_BOOLEAN)' failed
(rhythmbox:27863): GLib-CRITICAL **: g_variant_unref: assertion `value != NULL' failed
(rhythmbox:27863): GLib-CRITICAL **: g_variant_get_double: assertion `g_variant_is_of_type (value, G_VARIANT_TYPE_DOUBLE)' failed
(rhythmbox:27863): GLib-CRITICAL **: g_variant_get_string: assertion `value != NULL' failed
(rhythmbox:27863): Rhythmbox-CRITICAL **: rb_play_order_new: assertion `porder_name != NULL' failed
(rhythmbox:27863): GLib-GObject-WARNING **: invalid (NULL) pointer instance
(rhythmbox:27863): GLib-GObject-CRITICAL **: g_signal_connect_object: assertion `G_TYPE_CHECK_INSTANCE (instance)' failed
(rhythmbox:27863): Rhythmbox-CRITICAL **: rb_play_order_playing_source_changed: assertion `RB_IS_PLAY_ORDER (porder)' failed
Segmentation fault
