I wish to hide the grub menu, but with the right settings in /etc/default/grub, the grub menu is still displayed at boot. I run sudo update-grub after each edited. Bellow my grub file:
cat /etc/default/grub
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=2
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_TIMEOUT=0
GRUB_DISTRIBUTOR="`lsb_release -i -s 2> /dev/null || echo Debian`"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
With the following settings, I still have the menu display while it should not:
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=0
Same issue with:
GRUB_HIDDEN_TIMEOUT=5
GRUB_TIMEOUT=0
In fact, I have the same effect that the following:
#GRUB_HIDDEN_TIMEOUT=0
GRUB_TIMEOUT=10
Using Ubuntu 18.04 LTS with dual-boot windows. Ubuntu is the default entry in grub. I edit the file with sudo nano /etc/default/grub then I run sudo update-grub with success. Could you help me to really hide the grub menu please?
Edit:
Following the answer from abu_bua, the issue was solved with add GRUB_DISABLE_OS_PROBER=true here my new grub file:
GRUB_DEFAULT=0
GRUB_TIMEOUT=0
