I can connect to my home wifi network. However, internet browsing speed is just very slow.
Interesting fact is, I can connect to the same network from my Windows machine and I don't see any problems with speed. It seems this Ubuntu specific issue.
My Ubuntu laptop has IntelĀ® Dual Band Wireless-AC 3168. I did some research online, found that this issue could be related to linux-firmware. I am using v29.1044073957.0.
But still not sure what the problem is.
I ran wireless-info tool which generated this report.
Report shows some errors:-
[  213.909410] iwlwifi 0000:02:00.0: Microcode SW error detected.  Restarting 0x2000000.
[  213.909528] iwlwifi 0000:02:00.0: Start IWL Error Log Dump:
[  213.909530] iwlwifi 0000:02:00.0: Status: 0x00000100, count: 6
[  213.909532] iwlwifi 0000:02:00.0: Loaded firmware version: 29.1044073957.0
[  213.909534] iwlwifi 0000:02:00.0: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[  213.909535] iwlwifi 0000:02:00.0: 0x00800634 | trm_hw_status0
[  213.909537] iwlwifi 0000:02:00.0: 0x00000000 | trm_hw_status1
[  213.909538] iwlwifi 0000:02:00.0: 0x00043D54 | branchlink2
[  213.909539] iwlwifi 0000:02:00.0: 0x0004AFA6 | interruptlink1
[  213.909541] iwlwifi 0000:02:00.0: 0x00024558 | interruptlink2
[  213.909542] iwlwifi 0000:02:00.0: 0x00000000 | data1
[  213.909544] iwlwifi 0000:02:00.0: 0x00000080 | data2
[  213.909545] iwlwifi 0000:02:00.0: 0x07030000 | data3
[  213.909547] iwlwifi 0000:02:00.0: 0x0E80A919 | beacon time
[  213.909548] iwlwifi 0000:02:00.0: 0xF5FB26E5 | tsf low
[  213.909549] iwlwifi 0000:02:00.0: 0x00000033 | tsf hi
[  213.909551] iwlwifi 0000:02:00.0: 0x00000000 | time gp1
[  213.909552] iwlwifi 0000:02:00.0: 0x00C099B8 | time gp2
[  213.909554] iwlwifi 0000:02:00.0: 0x00000001 | uCode revision type
[  213.909555] iwlwifi 0000:02:00.0: 0x0000001D | uCode version major
[  213.909557] iwlwifi 0000:02:00.0: 0x3E3B4DE5 | uCode version minor
[  213.909558] iwlwifi 0000:02:00.0: 0x00000220 | hw version
[  213.909559] iwlwifi 0000:02:00.0: 0x00C89200 | board version
[  213.909561] iwlwifi 0000:02:00.0: 0x0ABD001C | hcmd
[  213.909562] iwlwifi 0000:02:00.0: 0xA4022002 | isr0
[  213.909564] iwlwifi 0000:02:00.0: 0x00000000 | isr1
[  213.909565] iwlwifi 0000:02:00.0: 0x0000000A | isr2
[  213.909566] iwlwifi 0000:02:00.0: 0x004028C5 | isr3
[  213.909568] iwlwifi 0000:02:00.0: 0x00000000 | isr4
[  213.909569] iwlwifi 0000:02:00.0: 0x0503001C | last cmd Id
[  213.909571] iwlwifi 0000:02:00.0: 0x00000000 | wait_event
[  213.909572] iwlwifi 0000:02:00.0: 0x00000080 | l2p_control
[  213.909573] iwlwifi 0000:02:00.0: 0x00012030 | l2p_duration
[  213.909575] iwlwifi 0000:02:00.0: 0x0000003F | l2p_mhvalid
[  213.909576] iwlwifi 0000:02:00.0: 0x00000080 | l2p_addr_match
[  213.909578] iwlwifi 0000:02:00.0: 0x00000007 | lmpm_pmg_sel
[  213.909579] iwlwifi 0000:02:00.0: 0x03041751 | timestamp
[  213.909580] iwlwifi 0000:02:00.0: 0x00342028 | flow_handler
Full Report:
I uploaded it here
Output of sudo dpkg -s linux-firmware
Package: linux-firmware
Status: install ok installed
Priority: optional
Section: misc
Installed-Size: 271097
Maintainer: Ubuntu Kernel Team <kernel-team@lists.ubuntu.com>
Architecture: all
Multi-Arch: foreign
Version: 1.173.1
Replaces: atmel-firmware, linux-firmware-snapdragon (<= 1.2-0ubuntu1), linux-restricted-common
Provides: atmel-firmware
Breaks: linux-firmware-snapdragon (<= 1.2-0ubuntu1)
Conflicts: atmel-firmware
Description: Firmware for Linux kernel drivers
 This package provides firmware used by Linux kernel drivers.
user1
  • 131
Try to create a configuration file, like so:
echo "options cfg80211 cfg80211_disable_40mhz_24ghz=Y" > /etc/modprobe.d/cfg80211.conf
And reboot.
This disables 40mHz support from the 2.4GHz band in the 802.11 subsystem (which is why it's an option for cfg80211 and not your wifi adapter's driver).
wxl
  • 1,026
Had similar issues with Wi-Fi Link 5100. The firmware (reliably) hangs when performing iperf3 transmit tests. The solution was to disable TX aggregation.
options iwlwifi 11n_disable=2
Other answers on the internet suggest using 11n_disable=1 but that disables 802.11n entirely.
Neko
