Ubuntu 18, trying to make zram to use lz4 compression.
Tried modifying /usr/bin/init-zram-swapping file
#!/bin/sh
for i in $(seq ${NRDEVICES}); do
  DEVNUMBER=$((i - 1))
  echo $mem > /sys/block/zram${DEVNUMBER}/disksize
  echo lz4 > /sys/block/zram${DEVNUMBER}/comp_algorithm # <= added this line
  mkswap /dev/zram${DEVNUMBER}
  swapon -p 5 /dev/zram${DEVNUMBER}
done
But, after rebootzramctl still shows I'm using lzo algortihm
NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram3 lzo           466M  2.9M 614.2K    1M       4 [SWAP]
/dev/zram2 lzo           466M  2.9M 631.2K    1M       4 [SWAP]
/dev/zram1 lzo           466M  2.9M 536.1K 1020K       4 [SWAP]
/dev/zram0 lzo           466M    3M   610K    1M       4 [SWAP]
I also tried adding adding it inrc.local, but it throws device already in use warning, because as far as I know, the change needs to be done before mkswap and swapon runs.
muru
  • 207,228
Sirajus Salekin
  • 1,737
  • 13
  • 29
This works:
# initialize the devices
  swapon -p 100 /dev/zram${DEVNUMBER}
done
Note: it seems you need to define the compression algorithm before zram size. Set swapon -p to priority level 100 to use zram actively as it improves performance.
matigo
  • 24,752
  • 50
  • 79
Modestas
  • 108
