Just rewriting this post so it's more clear.
I'm unable to get back to Windows after I burned Ubuntu to my USB Drive after using a program called "Rufus".
Now, when I attempt to boot Windows, even after I took out my USB Drive, it will still boot to Ubuntu.
I'm not sure about what to do to get back to Windows, and I'm worried because I had important photos and videos there as well.
When I attempt to get back to it, it says "No partitions detected", so this may be the problem.
EDIT #2 : The problem may be that I didn't select the "Try Ubuntu without installing" option, but rather the second one (I forget the name...).
Not sure what would actually happen if you did it, but maybe in rufus you installed onto the c drive. If this is the case it would start at the screnn asking if you want to install or try I think.
