-1
At "intramfs" what command to boot "fsck" to clear booting fault ? I have changed the computer battery and the boot process stops at a fault which ends with the prompt "initranfs". It says; /dev/sda1 ; UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY fsck ended with status code 4.
Can you tell me what to type from here, please ? John Scott.
Type fsck /dev/sda1 at the prompt and answer yes to all questions .. or fsck -y /dev/sda1 if you want to answer yes automatically - It can be quite a large number of prompts to answer. After that, reboot.
Soren A
  • 7,191
