I want to write a shell program which will go through all folders whose names match a pattern like this:
sudo sh  shell.sh   pub
When run, the script will look for all folders whose name contains pub and print its modification date. I wish to have code which will print results like in this image: enter image description here I have this code but it is not giving me the result I expect.
echo  'the folder '$1' was modified at ';
 find  -type d -name 'kam*'  -exec stat -c '%y %n' '{}' \;
I must go through every folder and output text echo 'the file '$1' was modified at '; and print the date like in the image.
I would like a result like this:
netcom@hotspot:~$ bash script.sh testRegex Pub
the folder testRegex was modified on may 15 01:19
 the folder Public was modified on may 19 01:19
  the folder Pubos was modified on may 19 01:19
Muh
  • 45
You can use find itself to print the whole thing:
for pattern
do
    find . -type d -name "*$pattern*" -printf 'The folder %P was modified on %t\n'
done
for pattern; do ... done loops over all the arguments, with the pattern variable set to each argument in turn.
With find, %P and %t give the path to the file and modification time in -printf.
muru
  • 207,228
You can use bash with the globstar option enabled as in the following script:
#!/bin/bash
shopt -s globstar
for i
  do for k in **/"$i"*/
    do stat -c "the folder %n was modified on %y" "$k"
  done
done
Save it as script, make it executable with chmod +x script and call it as you wanted it:
bash /path/to/script testRegex Pub
Note that this will search for e.g. Pub*, if you actually want to match *Pub*, change **/"$i"*/ to **/*"$i"*/. If you want to shorten the timestamp, try adding | sed 's/:[^:]*$//' to the end of the do stat line. You should also try %N instead of %n, especially when it comes to directory names with spaces this format is preferable.
If you want more fine-grained control over the date format you can use date, substitute the do stat line with the following:
do date -d@$(stat -c%Y "$k") +"the folder $k was modified on %b %d %R"
You can then use the usual date format sequences explained in man date, this one here prints e.g. May 15 01:19 as you requested.
Last but not least, to pretty-print the output of any of the above you can insert a tab after the directory name and use column as follows:
#!/bin/bash
shopt -s globstar
for i
    do date -d@$(stat -c%Y "$k") +"the folder $k%twas modified on %b %d %R"
  done
done | column -ts$'\t'
Example run
$ tree
├── 1
│   └── 1
│       └── 1
├── 1something
└── 2
    └── 1
$ bash -O globstar -c 'for i; do for k in **/"$i"*/; do stat -c "the folder %n was modified on %y" "$k"; done; done' _ 1
the folder 1/ was modified on 2018-06-07 09:45:28.098693507 +0200
the folder 1/1/ was modified on 2018-06-07 09:45:28.098693507 +0200
the folder 1/1/1/ was modified on 2018-06-07 09:45:28.098693507 +0200
the folder 1something/ was modified on 2018-06-07 09:55:36.066531665 +0200
the folder 2/1/ was modified on 2018-06-07 09:45:28.098693507 +0200
$ bash -O globstar -c 'for i; do for k in **/"$i"*/; do stat -c "the folder %n was modified on %y" "$k" | sed 's/:[^:]*$//'; done; done' _ 1
$ bash -O globstar -c 'for i; do for k in **/"$i"*/; do date -d@$(stat -c%Y "$k") +"the folder $k was modified on %b %d %R"; done; done' _ 1
the folder 1/ was modified on Jun 07 09:45
the folder 1/1/ was modified on Jun 07 09:45
the folder 1/1/1/ was modified on Jun 07 09:45
the folder 1something/ was modified on Jun 07 09:55
the folder 2/1/ was modified on Jun 07 09:45
$ bash -O globstar -c 'for i; do for k in **/"$i"*/; do date -d@$(stat -c%Y "$k") +"the folder $k%twas modified on %b %d %R"; done; done | column -ts'"$'\t'" _ 1
dessert
  • 40,956
The find command can do what you need with one line
You may have a look at the printf action in find
Seeman find for parameters details of printf
Example
find /PATH/TO/SCAN -type d -iname '*pub*' -printf "%p %TY-%Tm-%Td %TH:%TM\n"
-type d        : search for folders
-iname '*pub*' : find the pattern case insensitive
%p             : display path of found folder
%TY            : time Year
%Tm            : time month
%Td            : time day
%TH            : time hour
%TM            : time minutes
%TS            : time seconds
For more information
Official webpage for GNU find
25 Practical examples of the find command
cmak.fr
  • 8,976
Here's a slight variation, which makes use of -regex instead of -names:
find . -type d -regex ".*\($1\).*$" -printf 'The folder %P was modified on %Tb %Td %TH:%TM\n'
This can be either a single-line script or better yet - a function. Call it as so:
./finder.sh 'Vid\|Doc'
This makes for more idiomatic, grep-like approach.
dessert
  • 40,956
