let suppose I have folders with names af32, af42, af, and I want to print the last modification date of all folders whose have af* pattern for example . I writed shell that will take folder or files as parameter and return modification date for that folder .
stat -c %y "$1"
this code will return the last modification date to folder . but how can I apply this code to more than one folder whose have same pattern in their name
Muh
  • 45
You can use find to search recursively in search_folder/ for directories (-type d) matching a specific pattern glob (e.g. -name 'af*'):
find search_folder/ -type d -name 'af*' -exec stat -c '%y %n' '{}' \;
This will then execute (-exec ... \;) the command stat -c '%y %n' '{}' on each of the search results, replacing {} with the result path, starting with the given search_folder/.
Note that I modified your stat output to include the file name/path %n in the result, because otherwise you wouldn't see what file each modification date belongs to.
Byte Commander
  • 110,243
You can use shell globbing as follows:
stat -c %y af*/
af*/ matches every directory in the current directory beginning with “af”.
If this throws an error like
bash: /usr/bin/stat: Argument list too long
use this printf approach instead:
printf '%s\0' af*/ | xargs -0 stat -c %y
Example run
You might want to add %n to stat’s output…
$ ls
af  af32  af42  bf  cg45
$ stat -c %y af*/
2018-06-05 18:59:55.355277977 +0200
2018-06-04 19:01:28.968869600 +0200
2018-06-06 18:58:15.968639269 +0200
$ stat -c '%y %n' af*/
2018-06-05 18:59:55.355277977 +0200 af/
2018-06-04 19:01:28.968869600 +0200 af32/
2018-06-06 18:58:15.968639269 +0200 af42/
dessert
  • 40,956
