alhelal@VimLaTeX:~$ mysql -u root -p
Enter password:
ERROR 1698 (28000): Access denied for user 'root'@'localhost'
alhelal@VimLaTeX:~$ sudo mysql -u root -p
[sudo] password for alhelal:
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 35
Server version: 10.1.29-MariaDB-6 Ubuntu 18.04
Copyright (c) 2000, 2017, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]>
Why mariadb doesn't allow normal ubuntu user to enter mysql as mysql root user?
I also tried ERROR 1698 (28000): Access denied for user 'root'@'localhost' at Ubuntu 18.04 but failed?
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY 'test'' at line 1
alhelal
  • 2,741
According to this answer from SO, it could be because your root user is using the auth_socket plugin used by default in MySQL/MariaDB on Ubuntu.
MariaDB [mysql]> USE mysql;
MariaDB [mysql]> SELECT User, Host, plugin FROM mysql.user;
| User             | plugin                |
| root             | auth_socket           |
Changing this to mysql_native_password will allow you to connect without requiring sudo:
MariaDB [mysql]> UPDATE user SET plugin='mysql_native_password' WHERE User='root';
MariaDB [mysql]> FLUSH PRIVILEGES;
MariaDB [mysql]> exit;
$ service mysql restart
Erich
  • 143
