I'm both new to Ubuntu and Docker. I cut to the chase, when I create a volume using the sudo docker volume create TEST command, where should I expect to find the TEST volume and its data in my hard drive?
If I want it to be located in another drive, lets say D:\ (still new to ubuntu not sure if it also applies to linux) drive, what do I have to do?
Looks like it is /var/lib/docker/volumes
Here's what I got:
$ docker volume create TEST
$ ls /var/lib/docker/volumes
metadata.db  TEST/
Use docker volume inspect TEST (docs), and there will be a key "Mountpoint" with the path to it:
$ docker volume inspect TEST
        "CreatedAt": "2020-09-18T10:46:55-07:00",
        "Driver": "local",
        "Labels": {},
        "Mountpoint": "/var/lib/docker/volumes/TEST/_data",
        "Name": "TEST",
        "Options": {},
        "Scope": "local"
To extract just the path, for example to use in a script:
$ docker volume inspect --format '{{ .Mountpoint }}' TEST
On Ubuntu installations that use snap for installing docker the path is:
/var/snap/docker/common/var-lib-docker/volumes/
For 20.04 LTS snap is default.
If you're working on WSL2 through Docker Desktop for Windows, volumes will be found here:
/var/data/docker-desktop/default/daemon-data
If you are working on actual Ubuntu, then yes, as the above answer said it will be located in
pants
