37
Recently I booted Ubuntu 18.04 Live USB and I faced annoying problem. Screen was rotated and there was no rotate options in settings. I had to search not so obvious places in Internet, so I share this Q&A.
muru
  • 207,228
Qback
  • 1,093
You should use xrandr command. xrandr -o normal takes your screen back to normal (landscape) rotation.
Ubuntu 22:
instead of xrandr -o normal you should use xrandr -orientation normal
Qback
  • 1,093
You can use these commands:
xrandr --output $(xrandr |grep eDP|cut -d" " -f1) --rotate left
xrandr --output $(xrandr |grep eDP|cut -d" " -f1) --rotate normal
also right and inverted
I created a script here: https://gist.github.com/rubo77/d43cc5b3ff65d6df28b8b8c3c089f23b
with that script, you can simply call
rotatescreen.sh -r
rotatescreen.sh -l
rotatescreen.sh -i
rotatescreen.sh -n
Alternative, you can use CTRL+F8 to rotate using
gsettings set org.gnome.mutter.keybindings rotate-monitor "['XF86RotateWindows', '<Control>F8']"
see https://askubuntu.com/a/1184316/34298
rubo77
  • 34,024
  • 52
  • 172
  • 299
