What should i write in the: X-scheme-handler/mailto= ? I have Lotus Notes 8.5.2. It doesnt work if i just trying to change it from System Settings==>Default applications. It doesnt give the option to add Notes as a default but the calendat is ok and been set automaticly since i installed Notes.
Maybe i just need to know the right name of the application ant put it in:
Please help.
Jorge Castro
  • 73,717
MAX
Add the following to the end of /usr/share/applications/LotusNotes8.5.desktop, ie:
sudo gedit /usr/share/applications/LotusNotes8.5.desktop) and save the file:
MimeType=text/html;text/xml;application/xhtml+xml;application/xml;application/vnd.mozilla.xul+xml;application/rss+xml;application/rdf+xml;x-scheme-handler/mailto; TargetEnvironment=Messaging Menu;Unity
Next, run the following command:
sudo update-desktop-database -q
Go to System Settings > System Info and click on Default Applications. Lotus Notes 8.5 should now show up as an mail application option.
Bruno Pereira
  • 74,715
Editing the /usr/shar/.../.desktop shortcut did NOT work for me (13.04 raring).
What got me farther was based on an answer to another question
  1. Edit ~/.local/share/applications/mimeapps.list and add to the Default Applications section:
    x-scheme-handler/mailto=IBMNotes9.0.desktop
  2. sudo update-desktop-database
Once I had done that Notes showed as already selected in the "Details" app as my default mail application. Now mailto links will open notes, but it does not open a new composition window.
Any ideas for fixing the last mile here?
I had the same problem.
Changing %F to %U in the desktop-file fixed it for me.
thezulk
