After updating from 16.04 to 18.04, GNOME3 is to slow on my hardware (2010 dual core, 4GB, 128GB SSD)
So I decided to switch to Lubuntu, way faster.
All fine, except: there seems to be no password manager/keyring. So I installed seahorse and libpam-gnome-keyring.
Doesn't work, a terminal is still asking every time in the terminal for my ssh passwords. I can do ssh-add .ssh/id_rsa, but that will save the password only for terminal programs, not for the file-manager.
How do i get the Ubuntu behavior asking a passphrase once in a GUI dialog and saving it for the session for GUI programs and terminal?
It must be a LXDE config issue, all packages are there even when lubuntu-desktop is installed next to Ubuntu, it won't work using the lubuntu-environment.
journalctl | grep -i gnome-keyring-daemon
gnome-keyring-daemon[890]: couldn't set environment variable in session: GDBus.Error:org.freedesktop.DBus.Error.InvalidArgs: Type of message, '(ss)', does not match expected type '(s)'
Starting seahorse
(seahorse:1488): dbind-WARNING **: 08:36:27.966: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
Janghou
  • 6,035
At least the last error should be fixed by following the steps explained on this page: nm-applet running, indicator not in taskbar- new behavior in 16.04
For me (on Lubuntu 18.04) just installing the package at-spi2-core sufficed to get rid of this problem.
Seahorse is indeed made for Nautilus, but I found on https://forum.antergos.com/topic/1132/the-file-manager-pcmanfm-doesn-t-remember-passwords/5 the suggestion to install lxpolkit (or try polkit-gnome) and to make it start up automatically.
You can do this by using the non-GUI approach that is explained here: https://askubuntu.com/a/48327/575262
It states that you should add a .desktop file to ~/.config/autostart with a content like:
[Desktop Entry]
Type=Application
Name=<Name of application as displayed>
Exec=<command to execute>
Icon=<full path to icon>
Comment=<optional comments>
X-GNOME-Autostart-enabled=true
Does this work in your case?
ksyrium
  • 130
