During the Windows 10 update process, Windows 10 decided to overwrite your MBR bootloader. Which in the case before the update, was GRUB.
But after the update, Windows 10 replaced GRUB with BOOTMGR, Windows 10's bootloader.
1. Getting a boot-repair disk
boot-repair is a program that can:
- send computer info to Pastebin
- install GRUB on the bootloader
- configure grub
- and more!
If you run a 64-bit system, go here
If you run a 32-bit system, go here
2. Etching the image to a disk
Ironically, we will be using the popular image writer, Etcher.
To download Etcher, go here
Basically, just select your downloaded boot-repair-disk .iso
file and select a USB device.
WARNING: THIS CAN ERASE ALL DATA FROM YOUR USB. USE THIS PROGRAM WITH CAUTION.
3. Booting up.
To boot up to boot-repair, attach your USB disk, power on your computer, then start pressing the 'boot from...' key.
Select your disk.
You should start to boot up.
When you see a window that is titled, boot-repair or something similar...
Select Automated fix or the 1st option.
Only select "more options" if you are an experienced Linux user or have a friend to help!
It should start reinstalling and configuring GRUB (should be the latest one depending on your disk version).
When it is done, reboot if it asks you to. If it does not, open the power menu, and select reboot.
This time, select your boot disk (hard drive, SSD, etc.)\
You should see a menu. (GRUB!)
Select Windows or Ubuntu.
You should boot to said OS!
Follow this guide whenever you update Windows 10.
I hope this guide helped!
