I recently bought a Dell Inspiron 15" 5570, the version with Intel i5 8250u and just the iGPU intel UHD 620.
After installing Ubuntu i had some screen flickering and I managed it by using the Joakim's workaround but now I'm facing another problem which I couldn't figure out.
I need OpenGL 4, that the integrated gpu support but I don't know how to "enable" it.
That's the glxinfo | grep -i opengl output:
OpenGL vendor string: Intel Open Source Technology Center
OpenGL renderer string: Mesa DRI Intel(R) UHD Graphics 620 (Kabylake GT2)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 18.2.0-devel
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 18.2.0-devel
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 18.2.0-devel
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
And this is another glxinfo part which might be useful:
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel Open Source Technology Center (0x8086)
Device: Mesa DRI Intel(R) UHD Graphics 620 (Kabylake GT2) (0x5917)
Version: 18.2.0
Accelerated: yes
Video memory: 3072MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 4.5
Max compat profile version: 3.0
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
And this is the output error when I try to start the program which needs opengl 4:
X Error of failed request: GLXBadFBConfig
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 34 ()
Serial number of failed request: 40
Current serial number in output stream: 39
I've heard about such an alpha boot option to enable the alpha driver for my CPU but just miss that, thanks in advance for the help.
--UPDATE-- I actually "managed" the error, I tried other progams which needs openGL 4 funcionality, openGL 4.5 context, and works without problems but when I want to use this "legacy" OpenGL program which needs a 4.5 context
#include <cstdlib>
#include <cmath>
#include <iostream>
#ifdef __APPLE__
# include <GL/glew.h>
# include <GL/freeglut.h>
# include <OpenGL/glext.h>
#else
# include <GL/glext.h>
#pragma comment(lib, "glew32.lib")
#endif
#define PI 3.14159265358979324
using namespace std;
// Globals.
static float R = 40.0; // Radius of circle.
static float X = 50.0; // X-coordinate of center of circle.
static float Y = 50.0; // Y-coordinate of center of circle.
static int numVertices = 10; // Number of vertices on circle.
// Drawing routine.
void drawScene(void)
float t = 0; // Angle parameter.
glClear(GL_COLOR_BUFFER_BIT);
glColor3f(0.0, 0.0, 0.0);
// Draw a line loop with vertices at equal angles apart on a circle
// with center at (X, Y) and radius R, The vertices are colored randomly.
/* Funzione seno esercizio pag56 2.27
glBegin(GL_LINE_STRIP);
for(float i = -PI; i <= PI; i+=PI/20.0)
glColor3f((float)rand()/(float)RAND_MAX, (float)rand()/(float)RAND_MAX, (float)rand()/(float)RAND_MAX);
glVertex3f(i, sin(i), 0.0);
//cout<<"x="<<i<<";y="<<sin(i);
//t += 2 * PI / numVertices;
glEnd();*/
//Ellisse esercizio pag56 2.28
//x = X + A*cos(t), y = Y + B*sin(t), z=0, 0<=t<=2PI
glBegin(GL_LINE_LOOP);
for(int i = 0; i < numVertices; i++)
glVertex3f((R+10)*cos(t), (R-10)*sin(t), 0.0);
glEnd();
glFlush();
// Initialization routine.
void setup(void)
glClearColor(1.0, 1.0, 1.0, 0.0);
// OpenGL window reshape routine.
void resize(int w, int h)
glViewport(0, 0, w, h);
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
glOrtho(-50, 50, -50, 50, -1.0, 1.0);
glMatrixMode(GL_MODELVIEW);
glLoadIdentity();
// Keyboard input processing routine.
void keyInput(unsigned char key, int x, int y)
switch(key)
case 27:
exit(0);
break;
case '+':
numVertices++;
glutPostRedisplay();
break;
case '-':
if (numVertices > 3) numVertices--;
break;
default:
break;
// Routine to output interaction instructions to the C++ window.
void printInteraction(void)
cout << "Interaction:" << endl;
cout << "Press +/- to increase/decrease the number of vertices on the circle." << endl;
// Main routine.
int main(int argc, char **argv)
printInteraction();
glutInit(&argc, argv);
glutInitContextVersion(4,5);
glutInitContextProfile(GLUT_COMPATIBILITY_PROFILE);
glutInitDisplayMode(GLUT_SINGLE | GLUT_RGBA);
glutInitWindowSize(500, 500);
glutInitWindowPosition(100, 100);
glutCreateWindow("circle.cpp");
glutDisplayFunc(drawScene);
glutReshapeFunc(resize);
glutKeyboardFunc(keyInput);
glewExperimental = GL_TRUE;
glewInit();
setup();
glutMainLoop();
Gives the error:
But I can actually use it by starting it as follows:
MESA_GL_VERSION_OVERRIDE=4.5 ./circle
I don't know why maybe it is a bug, because when I try to compile the other programs, which works without MESA.. prefix, with: glutInitContextVersion(4, 6); Instead of: glutInitContextVersion(4, 5); It gives the same error of GLXBadFBConfig So there aren't any OpenGL wrong context settings mitigation in the program itself.
