The git developers talk of plumbing (low level) and porcelain (high level) commands.
useradd is plumbing. You should have used adduser (=porcelain) instead.
From useradd's manpage:
useradd is a low level utility for adding users. On Debian,
administrators should usually use adduser(8) instead.
When using useradd you need to specify literally everything, like a home directory and a login shell. adduser on the other hand has reasonable defaults for them. The experience you made is either due to having / as the home directory (no write permissions there) and/or a wrong no login shell, as @steeldriver noted in a comment. adduser handles all this. Thus:
adduser dsweb # create user with default settings (like $HOME, $SHELL)
adduser dsweb www-data # add him to group www-data
adduser dsweb sudo # ... and sudo
And yes, it's a real mess that we have two commands adduser and useradd. I myself always have to look up which is which.
To remove your previously created dsweb user, use deluser dsweb. Do not supply the --remove-home switch because you created him with / as $HOME and you don't want that removed.
