nvidia drivers on my kubuntu 18.04 dont work. I have tried apt install nvidia-driver-396 and apt install nvidia-driver-390.
nvidia x server settings is installed, but wont even open.
Changing drivers in driver management from nouveau to nvidia also doesnt work.
My GPU:
Nvidia Geforce mx150 2gb
guntbert
  • 13,475
Necho
First try to remove whatever you've installed:
sudo apt remove --purge nvidia-*
Then add the graphics drivers repository (for the latest Nvidia drivers):
sudo apt-add-repository ppa:graphics-drivers
Then try to let Kubuntu install the drivers:
 sudo ubuntu-drivers autoinstall
Reboot, see if it worked.
I had the same issue. I fixed it by removing the nomodeset parameter from the file /etc/default/grub.
So the line
GRUB_CMDLINE_LINUX="nomodeset"
should be changed to
GRUB_CMDLINE_LINUX=""
Then run sudo update-grub and reboot the laptop.
zx485
  • 2,865
From the Linux Mint Blog: Be careful with Kernel 4.15.0-24. A critical issue causes some computers to boot really slowly, or not to boot at all. Ubuntu is aware of it and working on a fix. We’ve also received negative feedback from the 4.15 kernel series in Mint 18.x (based on Ubuntu Xenial). Although Ubuntu decided to switch the HWE series towards it, the 4.15 series doesn’t appear to support some proprietary drivers yet (nvidia-3.04 and nvidia-340 among them).
I've got a custom-bult system with Ubuntu Gnome 16.04 and when the update to the 4.15.0-24 kernel came out, my system would not boot. In the grub menu I chose the 4.13.0-39 kernel and the system boots OK. So after any updates that require re-booting, I havve to manually select the 4.13.0-39 kernel. An Nvidia drver issue.No biggie...
Farad'n
  • 29
Have the same issue with k1100m, seems to be a kernel problem, for now, all you can do is either use noveau or downgrade your kernel. Also, don't forget to leave a bug report, that way we will get fixed faster
Also, Wayland doesn't support Nvidia anyway, so if you are on KDE go for Wayland, it has some neat features.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
N K
