After my recent upgrade (per new install) to Ubuntu 18.04, I have started having quite some troubles with my tool chain (Emacs, Lualatex, Evince). I am using forward/backward search to approximate WYSIWYG LaTeX editing.
Evince has started to crash on recompiling/updating LuaLaTeX. Then I tried zathura (another PDF viewer) instead, and after a view tries, similar crashes happen with zathura as well. Zathura after a while cannot even be started anymore by the commands Emacs issues to control zathura.
I am using Ubuntu 18.04 and the corresponding emacs, evince, and zathura packages as well as some "standard" emacs extensions from the ubuntu package repository.
The relevant portion of my .emacs:
(package-initialize)
(add-to-list 'load-path "~/.emacs.d/lisp/")
(add-hook 'text-mode-hook 'electric-pair-mode)
(add-hook 'text-mode-hook 'show-paren-mode)
(add-hook 'text-mode-hook 'turn-on-auto-fill)
(add-hook 'TeX-mode-hook 'outline-minor-mode)
(setq TeX-auto-save t)
(setq TeX-parse-self t)
(setq-default TeX-master nil)
(add-hook 'LaTeX-mode-hook 'flyspell-mode)
(add-hook 'LaTeX-mode-hook 'LaTeX-math-mode)
(add-hook 'LaTeX-mode-hook 'turn-on-reftex)
(setq reftex-plug-into-AUCTeX t)
(add-hook 'LaTeX-mode-hook 'company-mode)
(add-hook 'LaTeX-mode-hook 'TeX-source-correlate-mode)
(setq TeX-source-correlate-method 'synctex)
(setq TeX-source-correlate-start-server t)
(add-hook 'LaTeX-mode-hook 'TeX-PDF-mode)
(setq TeX-view-program-selection '((output-pdf "Zathura")))
Emacs generates the following call:
zathura file.pdf --synctex-forward 200:0:sometexinclude.tex -x "emacsclient
+%{line} %{input}"
Called like this, zathura (I do not use a zathura config file) exhibits the following:
zsh: segmentation fault (core dumped)  zathura file.pdf
Evince also crashes with SIGSEGV which leads me to believe that is a problem independent of the viewers.
The last thing I found out is that taking away the synctex.gz file makes it possible to start zathura and view the pdf output. But this is of course no desirable solution. However, I was not able to quickly find out how to find the core dump and make it human readable in this case. (That might exceed the scope of my problem.)
A description of that issue occurring with large documents in an OS X setting is described here: For me, it also happens more often the longer (60+ pages) the documents are, however, in my case under Linux.
Hope to get some help? (Should I transfer/share this question to/with the emacs community?)
mfg
  • 1,407
One solution that seems to work for me at the moment is to leave out the line
from my .emacs config. So, the minimum config to get forward/backward search to work again seems to be:
using evince (by default) and with one more line for using zathura:
Additionally, I changed from \include and \includeonly to a scheme commenting out unused latex includes. My theory is that hyperlinks (e.g. to bibrefs, sections, etc.) to pages maintained in the latex and synctex outputs but NOT generated into the pdf might cause some trouble in both of the PDF viewers I used.
A more reliable solution is to delete the .synctex.gz file. This for both evince and zathura solves the problem which will then only return every once in a while. However, I haven't been able to find a better solution so far. I should say that this is not really a practical solution anyway.
mfg
  • 1,407
