Can we boot encrypted squashfs from livecd. If it possible please suggest me to decrypt and boot the OS.
here i'm using luks encryption technique for securing the Squashfs file but i'm fail to decrypt that stored squashfs file container.
Thanks,
Below is a 'one step' bash script that creates an encrypted bootable livecd from an existing Ubuntu installation. (Tested/Working on Ubuntu 18.10)
Basically, the script copies the existing Ubuntu installation into a set of working directories at /tmp/livecd and:
When the ISO/IMG is booted on the machine or in a VM, the encrypted squashfs is transfered completely into ram, the user is asked to enter the proper passphrase, and the squashfs is then unencrypted and used to boot the system.
The rsync command line string can be modified to add/remove items that are copied from the existing Ubuntu installation when the encrypted livecd is being created.
EDIT: The script now handles images above the iso6990 4GB limit. If the created filesystem.squashfs file is above 4GB then a live-cd.img is created which is a bootable ext4 image housing the same files as the iso would have had. In addition, the script asks if you prefer to create and iso or an img when the filesystem.squahfs file is below the 4GB limit.
livecd.sh:
#!/bin/bash
echo
echo Setting up /tmp/livecd
echo
sudo mkdir -p /tmp/livecd/cd/{casper,boot/grub} /tmp/livecd/chroot/rootfs /tmp/livecd/mnt
echo
echo Installing necessary packages
echo
sudo apt-get update
sudo apt-get install -y grub2 xorriso squashfs-tools cryptsetup
echo
echo Copying over existing system
echo
sudo rsync -av --one-file-system --exclude=/swapfile --exclude=/proc/* --exclude=/dev/* \
--exclude=/sys/* --exclude=/tmp/* --exclude=/lost+found \
--exclude=/var/tmp/* --exclude=/boot/grub/* --exclude=/root/* \
--exclude=/var/mail/* --exclude=/var/spool/* --exclude=/media/* \
--exclude=/etc/fstab --exclude=/etc/mtab --exclude=/etc/hosts \
--exclude=/etc/timezone \
--exclude=/etc/X11/xorg.conf* --exclude=/etc/gdm/custom.conf \
--exclude=/etc/lightdm/lightdm.conf --exclude=/tmp/livecd/chroot/rootfs / /tmp/livecd/chroot/rootfs
echo
echo Setting up links to chroot
echo
sudo mount --bind /dev/ /tmp/livecd/chroot/rootfs/dev
sudo mount -t proc proc /tmp/livecd/chroot/rootfs/proc
sudo mount -t sysfs sysfs /tmp/livecd/chroot/rootfs/sys
sudo mount -o bind /run /tmp/livecd/chroot/rootfs/run
echo
echo Processing chroot commands
echo
cat <<'ABC' | sudo chroot /tmp/livecd/chroot/rootfs /bin/bash
LANG=
apt-get update
apt-get install -y casper lupin-casper
cat >> /etc/cryptsetup-initramfs/conf-hook <<'DEF'
CRYPTSETUP=Y
DEF
patch -d /usr/share/initramfs-tools/scripts /usr/share/initramfs-tools/scripts/casper-helpers <<'GHI'
@@ -141,6 +141,13 @@
losetup -o "$offset" "$dev" "$fspath"
else
losetup "$dev" "$fspath"
+ modprobe dm-crypt
+ mkdir /mnt
+ echo "Enter passphrase: " >&6
+ cryptsetup --type plain -c aes-xts-plain64 -h sha512 -s 512 open "$dev" squash >&6
+ mount -t ext4 /dev/mapper/squash /mnt
+ dev="$(losetup -f)"
+ losetup "$dev" /mnt/filesystem.squashfs
fi
echo "$dev"
return 0
GHI
depmod -a $(uname -r)
update-initramfs -u -k $(uname -r)
apt autoremove
apt clean
find /var/log -regex '.*?[0-9].*?' -exec rm -v {} \;
find /var/log -type f | while read file
do
cat /dev/null | tee $file
done
rm /etc/resolv.conf /etc/hostname
exit
ABC
echo
echo Copying chroot images to livecd
echo
export kversion=`cd /tmp/livecd/chroot/rootfs/boot && ls -1 vmlinuz-* | tail -1 | sed 's@vmlinuz-@@'`
sudo cp -vp /tmp/livecd/chroot/rootfs/boot/vmlinuz-${kversion} /tmp/livecd/cd/casper/vmlinuz
sudo cp -vp /tmp/livecd/chroot/rootfs/boot/initrd.img-${kversion} /tmp/livecd/cd/casper/initrd.img
sudo cp -vp /tmp/livecd/chroot/rootfs/boot/memtest86+.bin /tmp/livecd/cd/boot
echo
echo Removing chroot links
echo
sudo umount /tmp/livecd/chroot/rootfs/proc
sudo umount /tmp/livecd/chroot/rootfs/sys
sudo umount /tmp/livecd/chroot/rootfs/dev
echo
echo Creating the squashfs file
echo
sudo mksquashfs /tmp/livecd/chroot/rootfs /tmp/livecd/filesystem.squashfs -noappend
echo
echo Setting up encrypted squashfs file
echo
size=$(du --block-size=1 /tmp/livecd/filesystem.squashfs | awk '{print $1}')
((size=size+size/10))
((size=size/1024))
echo $size
sudo dd if=/dev/zero of=/tmp/livecd/cd/casper/filesystem.squashfs bs=1024 count=$size status=progress
dev="$(losetup -f)"
sudo losetup "$dev" /tmp/livecd/cd/casper/filesystem.squashfs
echo
echo Enter a large string of random text below to setup the pre-encryption.
echo
sudo cryptsetup --type plain -c aes-xts-plain64 -h sha512 -s 512 open "$dev" squash
echo
echo Pre-encrypting entire squshfs with random data
echo
sudo dd if=/dev/zero of=/dev/mapper/squash bs=1M status=progress
sync
sync
sync
sync
sudo cryptsetup close squash
echo
echo Enter the desired passphrase for the encrypted livecd below.
echo
echo
echo Creating ext4 into encrypted container
echo
sudo mkfs.ext4 -m 0 /dev/mapper/squash
sudo mount -t ext4 /dev/mapper/squash /tmp/livecd/mnt
echo
echo Moving unencrypted squashfs file into encrypted sqaushfs container
echo
sudo mv /tmp/livecd/filesystem.squashfs /tmp/livecd/mnt
sync
sync
sync
sync
sudo umount /tmp/livecd/mnt
sudo losetup -d "$dev"
echo
echo Creating size and md5sum cd files
echo
echo -n $(sudo du -s --block-size=1 /tmp/livecd/chroot/rootfs | tail -1 | awk '{print $1}') | sudo tee /tmp/livecd/cd/casper/filesystem.size
find /tmp/livecd/cd -type f -print0 | sudo xargs -0 md5sum | sed "s@/tmp/livecd/cd@.@" | grep -v md5sum.txt | sudo tee -a /tmp/livecd/cd/md5sum.txt
echo
echo Creating grub.cfg for the livecd
echo
sudo bash -c 'cat > /tmp/livecd/cd/boot/grub/grub.cfg <<EOF
set default="0"
set timeout=10
menuentry "Ubuntu GUI from RAM" {
linux /casper/vmlinuz boot=casper toram quiet
initrd /casper/initrd.img
EOF'
filesize=$(sudo du --block-size=1 -s /tmp/livecd/cd/casper/filesystem.squashfs | tail -1 | awk '{print $1}')
echo "filesystem.squashfs size: $filesize"
devflag=0
if [ $filesize -lt 4294967295 ]
then
echo
echo filesystem.squashfs is under the 4GB iso6990 limit
echo
echo "Create a bootable iso or bootable device img for (usb, hd)?"
select yn in "iso" "dev"; do
case $yn in
iso ) echo;
echo Creating bootable ISO at /tmp/livecd for the now encrypted livecd;
echo;
sudo grub-mkrescue -o /tmp/livecd/live-cd.iso /tmp/livecd/cd;
echo
echo COMPLETE!
echo
break;;
dev ) devflag=1;
break;;
esac
done
else
devflag=1
fi
if [ $devflag -eq 1 ]
then
echo
echo Setting up /tmp/livecd/live-cd.img
echo
filesize=$(sudo du -s --block-size=1 /tmp/livecd/cd | tail -1 | awk '{print $1}')
((filesize=filesize+filesize/10))
((filesize=filesize/1024))
sudo dd if=/dev/zero of=/tmp/livecd/live-cd.img bs=1024 count=$filesize status=progress
dev="$(losetup -f)"
sudo losetup $dev /tmp/livecd/live-cd.img
echo
echo Formating /tmp/livecd/live-cd.img to ext4
echo
sudo mkfs.ext4 -m 0 $dev
echo
echo Installing grub and copying live system files
echo
sudo mount -t ext4 $dev /tmp/livecd/mnt
sudo grub-install --no-floppy --force --root-directory=/tmp/livecd/mnt $dev
sudo rsync -av --one-file-system /tmp/livecd/cd/ /tmp/livecd/mnt
sync
sync
sync
sync
sudo losetup -d $dev
echo
echo COMPLETE!
echo live-cd.img can now be written to a usb or hard drive using dd or similar
echo
fi
