I recently migrated from Ubuntu 12.04LTS to 14.04 LTS .I had issues with my 12.04 so I did a factory restore and then upgraded to 14.04.My system is upgraded to 14.04 with no issues but The first thing I see is after restarting a pop up comes system problem detected.If I cancel it I don't see any issues,however the real problem is when I try to install nodejs using the below link---
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
then I see some weird erros---------
Fetched 23.7 MB in 23s (1,028 kB/s)
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/main/source/Sources  Hash Sum mismatch
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/main/binary-amd64/Packages  Hash Sum mismatch
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/main/binary-i386/Packages  Hash Sum mismatch
E: Some index files failed to download. They have been ignored, or old ones used instead.
I did try with below solution sudo rm -vf /var/lib/apt/lists/* but it again gives this error rm: cannot remove ‘/var/lib/apt/lists/partial’: Is a directory
Please help me on this as I am struggling with this.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
