Usually, before beginning my coding duty I open the following:
- google-chrome
- nautilus
- terminal
- system monitor
- gedit
Is there a way to open all of them with a single terminal command?
I use Ubuntu 18.04.
I use Ubuntu 18.04.
Here's what I'd do:
for i in google-chrome nautilus gnome-terminal gedit ; do
setsid "$i" > /dev/null 2>&1
done
setsid or nohup can be used to daemonize a process, with setsid being preferred because it starts each process as new session leader, effectively disconnecting it from terminal. See also, Difference between nohup, disown and &.
As for > /dev/null 2>&1 that just sends both normal and error streams from each program into /dev/null so that you can still use terminal normally. See also What does & mean exactly in output redirection? and What is the differences between &> and 2>&1
I don't remember command for system monitor off the top of my head, so I'll leave that up to you.
Feel free to turn this loop into either a function that can live in your ~/.bashrc or make a full-blown scripts. Up to you.
To open all of the above applications at one, you could execute something like this:
chromium ; nautilus ; gnome-terminal ; gnome-system-monitor ; gedit
To make this startup every time you Log In, you could put this command into a .desktop file on the Exec= line.
Place this file into /usr/share/applications and open gnome-session-properties. Simply add your new application to the current list of startup applications. This should do the trick.
