I am trying to make a script which is supposed to open a new gnome-terminal and issue a command (launch a jetty server).
If I try only : gnome-terminal, a new gnome-terminal is opened.
If I try : gnome-terminal -e ls, I get a warning message :
Option ā-eā is deprecated and might be removed in a later version of gnome-terminal.
Use ā-- ā to terminate the options and put the command line to execute after it.
Here, the new gnome-terminal is not always opened. If I try this command fast 10 times, maybe 2 terminal will open...
Same if I try with the recommended syntax : gnome-terminal -- ls.
What is the correct way to achieve this?
