-1
This is related to a question i asked in overflow, It remains unanswered so i though I'd try asking it in segments
My objective is to return the special \n function, If i were to run
echo -e "My name is \nnick rock and i \nlive by the sea shore." > file
Then when i cat that file you get something like this
My name is
nick rock and i
What I'm looking to do is reverse the \n return function, so when i echo the file with something like this
echo -aoE '([a-zA-Z]){1,5}' file
output
My
name
is
nick
rock
and
i
live
by
the
sea
shore.
I'll get this instead
My name is nick rock and i live by the sea shore
muru
  • 207,228
you can use this command line, it's an improvement of @Sergiv Kolodyazhnyy which print the \n at the right place
while IFS= read -r line || [ -n "$line" ]; do printf "%s " "$line" ; printf "\n" ; done < test.txt
(sorry to not be able to comment)
damadam
  • 2,873
You can also echo unquoted command-substitution:
echo $(<infile)
αғsнιη
  • 36,350
What you're looking for is
$ tr  '\n' ' ' < file
My name is  nick rock and i  live by the sea shore.
tr utility is for translating sets of characters, in this there's only one character \n in SET1 and space in SET2. As for < file, that just redirects the file into program's stdin stream.
But if for some reason you need a shell-only way, then this is sufficient:
$ while IFS= read -r line || [ -n "$line" ]; do printf "%s " "$line" ; done < file
Here are some options:
  1. using awk, with an unset record separator (aka 'paragraph mode') and the default field separator
    awk -vRS= '{$1=$1} 1' file
  2. using xargs with no explicit command
    $ xargs < file
  3. using fmt from GNU coreutils:
    $ fmt file
steeldriver
  • 142,475
