125
I need to a copy file and after that I need to change the timestamp attributes as the original file. How can I do it with the terminal or any other way?
You can preserve the timestamp of the original file when copying using cp by adding the -p or --preserve option:
   -p     same as --preserve=mode,ownership,timestamps
--preserve[=ATTR_LIST] preserve the specified attributes (default: mode,ownership,time‐ stamps), if possible additional attributes: context, links, xattr, all
So to preserve only the timestamp
cp --preserve=timestamps oldfile newfile
or to preserve mode and ownership as well
cp --preserve oldfile newfile
or
cp -p oldfile newfile
Additional options are available for recursive copying - a common one is cp -a (cp --archive) which additionally preserves symbolic links.
steeldriver
  • 142,475
56
If you want to preserve the original timestamps, use
$ touch -r <original_file> <new_file>
This copies the timestamps from another file.
See this blog post for more: Fake File Access, Modify and Change TimeStamps
wjandrea
  • 14,504
If for instance you forgot the cp -p parameter and need to replace timestamps with their originals recursively without recopying all the files. Here is what worked for me:
find /Destination -exec bash -c 'touch -r "${0/Destination/Source}" "$0"' {} \;
This assumes a duplicate file/ folder tree of Source: /Source and Destination: /Destination
  1. find searches the Destination for all files & dirs (which need timestamps) and -exec ... {} runs a command for each result.
  2. bash -c ' ... ' executes a shell command using bash.
  3. $0 holds the find result.
  4. touch -r {timestamped_file} {file_to_stamp} uses a bash replace command ${string/search/replace} to set timestamp source appropriately.
  5. the Source and Destination directories are quoted to handle dirs with spaces.
