I was getting dns probe finished message in chrome on Ubuntu 18.04 so I looked up on the internet and tried to run the following commands.
sudo rm/etc/resolv.conf
sudo ln -s /var/run/resolvconf/resolv.conf /etc/resolv.conf
Above 2 commands executed successfully but the following didn't.
sudo resolvconf -u
It gives an error message that resolvconf is not installed.
Now, nothing is working and /etc/resolv.conf file is empty. I'm not even able to edit it (I tried to a add nameserver 8.8.8.8).
Please help.
Edit: i'm still getting ERR_NAME_NOT_RESOLVE and here's the output of 'service --status-all`.
 [ + ]  acpid
 [ - ]  alsa-utils
 [ - ]  anacron
 [ + ]  apparmor
 [ + ]  apport
 [ + ]  avahi-daemon
 [ + ]  bluetooth
 [ - ]  console-setup.sh
 [ + ]  cron
 [ + ]  cups
 [ + ]  cups-browsed
 [ + ]  dbus
 [ - ]  dns-clean
 [ + ]  gdm3
 [ + ]  grub-common
 [ - ]  hwclock.sh
 [ + ]  irqbalance
 [ + ]  kerneloops
 [ - ]  keyboard-setup.sh
 [ + ]  kmod
 [ + ]  network-manager
 [ + ]  networking
 [ - ]  plymouth
 [ - ]  plymouth-log
 [ - ]  pppd-dns
 [ + ]  procps
 [ - ]  rsync
 [ + ]  rsyslog
 [ - ]  saned
 [ + ]  speech-dispatcher
 [ - ]  spice-vdagent
 [ + ]  udev
 [ + ]  ufw
 [ + ]  unattended-upgrades
 [ - ]  uuidd
 [ + ]  whoopsie
 [ - ]  x11-common
आनंद
  • 215
To fix this you should recreate the link how it was. On 18.04 /etc/resolv.conf points to ../run/systemd/resolve/stub-resolv.conf.
So to fix your problem it should be enough to do the following:
sudo rm resolv.conf
sudo ln -s /run/systemd/resolve/stub-resolv.conf /etc/resolv.conf
Videonauth
  • 33,815
I had exactly the same issue and just removed the resolv.conf file by using the same commands! here is how I fixed it: if you are using gnome, then: sudo service network-manager restart this will recreate all the necessary files automatically.
