I have recently downloaded Ubuntu 18.04 amd 64 bit version to try on my (Sony Vaio Intel® Core™ i3-2330M CPU @ 2.20GHz × 4, RAM 4GB) system. Then I have created a live boot-able usb(8GB) with help of first Unetbootin & then YUMI. While creating the live usb I have chosen 3072MB as size of the persistent file(casper-rw).
On first run it booted and the take me to the live user session. But when I tried to start Firefox it had crashed - so I have to end that session there.
Now when-ever I have tried to start a live session with the persistent file system active it fails to start, but if I remove the persistent file system entry checking by the boot loader it works fine and the 'live user session' could be started.
I need the 'persistent file' for saving internet downloading history so that I can resume download of unfinished files.
Please help me.
Persistent live systems are very portable between computers
  • Persistent live systems are very portable, which is a good reason to use them.
Persistent live systems are sensitive to corruption
  • if the system crashes (which happened to you)
  • if you unplug the pendrive without unmounting the mounted partition(s) which means that you must shut down gracefully and let the shutdown process finish
  • if you install too many program packages or update & upgrade completely.
I suggest that you try a persistent live system made with mkusb. See the following links,
You should backup your system often.
Installed systems in external drives are portable and stable
Installed systems in external drives are portable,
  • but not as portable as persistent live systems
  • you can install program packages and update & upgrade completely like any installed system (as long as there is drive space for it)
  • but if you unplug the pendrive before shutting down gracefully and let the shutdown process finish, this file system will probably be corrupted too.
This might be an alternative for you, if portable enough. See this link,
Repair the ext file system in casper-rw
If the file system in the casper-rw partition or file is not too corrupted, you can get a working USB pendrive again after repairing the file system.
  • Boot from another linux system
  • check that casper-rw is not mounted
  • Run the following repair command
    sudo e2fsck -f /dev/sdxn
    where x is the device letter and n is the partition number, so typically for a persistent live drive by mkusb
    sudo e2fsck -f /dev/sdb5
    See this link for more details,
  • If you stay with a casper-rw file, you can try the following command
    sudo e2fsck -f mountpoint-of-FAT-partition/casper-rw
    Example:
    $ sudo e2fsck -f /mnt/sd1/casper-rw
    e2fsck 1.44.1 (24-Mar-2018)
    Pass 1: Checking inodes, blocks, and sizes
    Pass 2: Checking directory structure
    Pass 3: Checking directory connectivity
    Pass 4: Checking reference counts
    Pass 5: Checking group summary information
    /mnt/sd1/casper-rw: 11/262144 files (0.0% non-contiguous), 18510/1048320 blocks
sudodus
  • 47,684
