vishwas@vishwas-Inspiron-15-3567:~$ pip3 install cv2
Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 33, in vendored
__import__(vendored_name, globals(), locals(), level=0)
ImportError: No module named 'pip._vendor.pkg_resources'
During handling of the above exception, another exception occurred:
File "/usr/bin/pip3", line 9, in <module>
from pip import main
File "/usr/lib/python3/dist-packages/pip/__init__.py", line 13, in <module>
from pip.exceptions import InstallationError, CommandError, PipError
File "/usr/lib/python3/dist-packages/pip/exceptions.py", line 6, in <module>
from pip._vendor.six import iteritems
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 75, in <module>
vendored("pkg_resources")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 634, in _load_backward_compatible
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2927, in <module>
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2913, in _call_aside
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2952, in _initialize_master_working_set
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 956, in subscribe
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2952, in <lambda>
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2515, in activate
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2097, in declare_namespace
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2047, in _handle_ns
File "/usr/share/python-wheels/pkg_resources-0.0.0-py2.py3-none-any.whl/pkg_resources/__init__.py", line 2066, in _rebuild_mod_path
AttributeError: '_NamespacePath' object has no attribute 'sort'
Asked
Active
Viewed 571 times
Elder Geek
- 36,752
You need to install setuptools for Python3:
sudo apt-get install python3-setuptools
Florian Diesch
- 89,643
