I am unable to upgrade to Ubuntu 18.04 as due to wrong links in sources.list file. I am able to update successfully as only some of the links are wrong. As Ubuntu 17.10 repositories are not yet moved to old-release, I am unable to update when i replace archive to old-release. And with unchanged sources.list file, some of the links are not working-
Get:16 http://archive.ubuntu.com/ubuntu bionic/universe i386 Packages [8,531 kB]
Err http://archive.ubuntu.com/ubuntu bionic/universe i386 Packages
Connection failed [IP: 91.189.88.161 80]
Err http://archive.ubuntu.com/ubuntu bionic/universe amd64 Packages
Connection failed [IP: 91.189.88.152 80]
Can someone tell the solution, or post their sources.list file to check the difference?
Kulfy
  • 18,154
BEWARB
  • 1,029
A standard sources.list file for Ubuntu 17.10 (Artful Aardvark) looks like this:
deb http://archive.ubuntu.com/ubuntu/ artful main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ artful-updates main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ artful-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu artful-security main restricted universe multiverse
deb http://archive.canonical.com/ubuntu artful partner
A standard sources.list file for Ubuntu 18.04 looks the same as the above sources.list except all 5 times artful appears it is replaced by bionic
Make sure to run this command after changing sources.list to refresh the list of available software.
sudo apt update
karel
  • 122,292
  • 133
  • 301
  • 332
