Need to be able to edit this file: /sys/class/net/eth0/queues/rx-0/rps_cpus
The file permissions:
cd:/sys/class/net/eth0/queues/rx-0$ ls -l
total 0
-rw-r--r-- 1 root root 4096 2012-02-13 17:23 rps_cpus
-rw-r--r-- 1 root root 4096 2012-02-13 12:54 rps_flow_cnt
cd :/sys/class/net/eth0/queues/rx-0$**
Tried this:
$ sudo rm /sys/class/net/eth0/queues/rx-0/rps_cpus; sudo sh -c "echo 1 > /sys/class/net/eth0/queues/rx-0/rps_cpus"
rm: cannot remove `/sys/class/net/eth0/queues/rx-0/rps_cpus': Operation not permitted
Jorge Castro
  • 73,717
Ringtail
  • 16,285
The files under /sys/ aren't real files, they're representations of the kernel's internal state. You can tweak kernel parameters by writing stuff to them, but as they are not actual files, you cannot delete them.
If what you want is to put a "1" there, try this:
echo 1 | sudo tee /sys/class/net/eth0/queues/rx-0/rps_cpus
See the answer to this question for an explanation of the "sudo tee" trick and why it's useful in this case.
Read more about /sys/ here: http://en.wikipedia.org/wiki/Sysfs
roadmr
  • 34,802
