I have no hard drive installed, Only USB thumb drive. Will this be a problem?
Asked
Active
Viewed 9,167 times
13
It will work just fine. I've often used it as a tool to diagnose computers with hard drives that have quit working.
If you want to save stuff, you could plug in a thumb drive or a USB hard drive and save it to that. A thumb drive will show up just like it would on a normal Ubuntu install.
Another option if you want persistence is to make a LiveUSB drive with Ubuntu's startup disk creator and use the option to have persistence.
It should work fine, I've used a live CD on machines with totally broken hard drives with no problem.
If you want persistence you'll need to boot off a USB key instead of a CD.
Jorge Castro
- 73,717
As long as you have RAM go for it, a LiveCD does not need a hard disk or even a writable media installed to run properly.
Bruno Pereira
- 74,715
