You're better off pasting code to python interpreter. In the shell, however, you can start here-doc redirection with python <<EOF, paste code, and close it with EOF. Like so:
$ python3 <<EOF
> for i in range(5):
> print(i)
> EOF
Of course, make sure you're using proper Python version and your code syntax matches that.
If you wanna get creative, install xclip package to access clipboard contents programmatically ( installation is done via sudo apt-get install xclip) and create the following function in your .bashrc, then source it:
pyfromclip(){ python3 < <(xclip -o -sel clip); }
This function uses process substitution < <() feature of bash, and redirects output of xclip, which releases clipboard contents to its stdout stream, into python's stdin stream.
$ cat ./hello_world.py
d = { "Hello": 1, "World": 2 }
for key,value in d.items():
print(key,value)
$ xclip -sel clip ./hello_world.py
$ # We copied into clipboard, so now let's run it
$ pyfromclip
Hello 1
World 2
