Busybox v1. 22. 1 (Ubuntu 1:1. 22. 0-19ubuntu2) built-in shell (ash) enter 'help' for a list of built-in commands.
Asked
Active
Viewed 111 times
It should be showing you that the file system has uncleaned blocks. The message should be like this:
/dev/sda1 contains a file system with errors, check forced.
Inodes that were part of a corrupted orphan linked list found.
/dev/sda1: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
fsck exited with status code 4
The root filesystem on `/dev/sda1` requires a manual `fsck`
BusyBox v1.22.1 (Ubuntu 1:1.22.0-15ubuntu1) built-in shell (ash)
Enter 'help' for a list of built-in-commands.
(initramfs)_
Anyways, you should first determine which partition you need to clean. In the above example, /dev/sda1 is the partition. According to the example, now you just need to run:
fsck /dev/sda1
Then press y key when asked for confirmation. And after that just press Enter when it asks for any more confirmation.
That's all. After it finishes cleaning the partition, type exit. And within a few seconds, you will boot up normally.
pro neon
- 119
