I have two lidars. And in my code I need to provide the lidar port: ttyUSB0/ttyUSB1 etc...
I have this udev rule. (/etc/udev/rules.d/rplidar.rules) rplidar.rules
# set the udev rule , make the device_port be fixed by rplidar
KERNEL=="ttyUSB*", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", MODE:="0777", SYMLINK+="rplidar"
By making this I can simply call port=rplidar in my code. But now I have two rplidars that have the same idVendor and idProduct, how can I distinguish them and create an additional rule for the second lidar?
When I plugged in only one device, this is how I did it
$ udevadm info -a -n /ttyUSB0
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
  looking at device '/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.0/ttyUSB0/tty/ttyUSB0':
    KERNEL=="ttyUSB0"
    SUBSYSTEM=="tty"
    DRIVER==""
  looking at parent device '/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.0/ttyUSB0':
    KERNELS=="ttyUSB0"
    SUBSYSTEMS=="usb-serial"
    DRIVERS=="cp210x"
    ATTRS{port_number}=="0"
  looking at parent device '/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.0':
    KERNELS=="1-1.1:1.0"
    SUBSYSTEMS=="usb"
    DRIVERS=="cp210x"
    ATTRS{authorized}=="1"
    ATTRS{bAlternateSetting}==" 0"
    ATTRS{bInterfaceClass}=="ff"
    ATTRS{bInterfaceNumber}=="00"
    ATTRS{bInterfaceProtocol}=="00"
    ATTRS{bInterfaceSubClass}=="00"
    ATTRS{bNumEndpoints}=="02"
    ATTRS{interface}=="CP2102 USB to UART Bridge Controller"
    ATTRS{supports_autosuspend}=="1"
  looking at parent device '/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1':
    KERNELS=="1-1.1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{avoid_reset_quirk}=="0"
    ATTRS{bConfigurationValue}=="1"
    ATTRS{bDeviceClass}=="00"
    ATTRS{bDeviceProtocol}=="00"
    ATTRS{bDeviceSubClass}=="00"
    ATTRS{bMaxPacketSize0}=="64"
    ATTRS{bMaxPower}=="100mA"
    ATTRS{bNumConfigurations}=="1"
    ATTRS{bNumInterfaces}==" 1"
    ATTRS{bcdDevice}=="0100"
    ATTRS{bmAttributes}=="80"
    ATTRS{busnum}=="1"
    ATTRS{configuration}==""
    ATTRS{devnum}=="28"
    ATTRS{devpath}=="1.1"
    ATTRS{ltm_capable}=="no"
    ATTRS{manufacturer}=="Silicon Labs"
    ATTRS{maxchild}=="0"
    ATTRS{product}=="CP2102 USB to UART Bridge Controller"
    ATTRS{quirks}=="0x0"
    ATTRS{removable}=="unknown"
    ATTRS{serial}=="0001"
    ATTRS{speed}=="12"
    ATTRS{urbnum}=="17"
    ATTRS{version}==" 1.10"
  looking at parent device '/devices/pci0000:00/0000:00:14.0/usb1/1-1':
    KERNELS=="1-1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{bDeviceClass}=="09"
    ATTRS{bDeviceProtocol}=="02"
    ATTRS{bMaxPower}=="0mA"
    ATTRS{bcdDevice}=="0286"
    ATTRS{bmAttributes}=="e0"
    ATTRS{busnum}=="1"
    ATTRS{devnum}=="13"
    ATTRS{devpath}=="1"
    ATTRS{idProduct}=="2744"
    ATTRS{idVendor}=="0424"
    ATTRS{manufacturer}=="Microchip Tech"
    ATTRS{maxchild}=="4"
    ATTRS{product}=="USB2744"
    ATTRS{removable}=="removable"
    ATTRS{speed}=="480"
    ATTRS{urbnum}=="331"
    ATTRS{version}==" 2.10"
  looking at parent device '/devices/pci0000:00/0000:00:14.0/usb1':
    KERNELS=="usb1"
    SUBSYSTEMS=="usb"
    DRIVERS=="usb"
    ATTRS{authorized_default}=="1"
    ATTRS{bDeviceProtocol}=="01"
    ATTRS{bcdDevice}=="0413"
    ATTRS{busnum}=="1"
    ATTRS{devnum}=="1"
    ATTRS{devpath}=="0"
    ATTRS{idProduct}=="0002"
    ATTRS{idVendor}=="1d6b"
    ATTRS{interface_authorized_default}=="1"
    ATTRS{manufacturer}=="Linux 4.13.0-38-generic xhci-hcd"
    ATTRS{maxchild}=="16"
    ATTRS{product}=="xHCI Host Controller"
    ATTRS{serial}=="0000:00:14.0"
    ATTRS{speed}=="480"
    ATTRS{urbnum}=="75264"
    ATTRS{version}==" 2.00"
  looking at parent device '/devices/pci0000:00/0000:00:14.0':
    KERNELS=="0000:00:14.0"
    SUBSYSTEMS=="pci"
    DRIVERS=="xhci_hcd"
    ATTRS{broken_parity_status}=="0"
    ATTRS{class}=="0x0c0330"
    ATTRS{consistent_dma_mask_bits}=="64"
    ATTRS{d3cold_allowed}=="1"
    ATTRS{device}=="0xa12f"
    ATTRS{dma_mask_bits}=="64"
    ATTRS{driver_override}=="(null)"
    ATTRS{enable}=="1"
    ATTRS{irq}=="126"
    ATTRS{local_cpulist}=="0-7"
    ATTRS{local_cpus}=="ff"
    ATTRS{msi_bus}=="1"
    ATTRS{numa_node}=="-1"
    ATTRS{revision}=="0x31"
    ATTRS{subsystem_device}=="0x201f"
    ATTRS{subsystem_vendor}=="0x1043"
    ATTRS{vendor}=="0x8086"
  looking at parent device '/devices/pci0000:00':
    KERNELS=="pci0000:00"
    SUBSYSTEMS==""
    DRIVERS==""
Zanna
  • 72,312
You can use the %n like this
SYMLINK+="rplidar%n"
if you are ok with numbered device by Kernel. The number that sits in %n is decided by kernel.
zx485
  • 2,865
get the programmer from siliconelab and edit the CP2102 USB to UART Bridge Controller parametre. preaty fast to do, like 5 min The each device will have they own name and serial...
the exe we use is: install_USBXpress_SDK.exe
