On my bionic 'clients' I get:
GPG error: http://repo.localpod/Dml/ldom-debs/ubuntu bionic InRelease: The following signatures were invalid: ADE541A20ACF8997C01BDCF7090678A30132048A
Note that it says "invalid", not missing!
These are my own .deb packages, collected in a repo. ( this works fine for trusty & xenial )
I have signed the repo with something like: ( called via reprepro: conf/distributions )
gpg --batch --yes --keyring $KeyP --secret-keyring $KeyS -a --no-permission-warning --detach-sign --default-key 'ldom install service' --output $3 $1
$1 = .../Release
$2 = .../InRelease
ok, so i tried:
wget http://repo.localpod/Dml/ldom-debs/ubuntu/dists/bionic/InRelease
and:
# gpgv --keyring /etc/apt/trusted.gpg "InRelease"
gpgv: Signature made Thu 24 May 2018 12:20:29 PM CEST
gpgv: using DSA key 090678A30132048A
gpgv: Good signature from "ldom install service <tbuunix@...dk>"
Is this not, more or less, how apt-get checks signatures? Or is key too old? wrong type ?
full error:
apt-key list
pub rsa2048 2014-06-24 [SC]
754A 1A7A E731 F165 D5E6 D4BD 0E08 A149 DE57 BFBE
uid [ unknown] SaltStack Packaging Team <packaging@saltstack.com>
sub rsa2048 2014-06-24 [E]
pub dsa1024 2013-06-10 [SCA]
ADE5 41A2 0ACF 8997 C01B DCF7 0906 78A3 0132 048A
uid [ unknown] LDOM install service <tbuunix@....dk>
sub elg1024 2013-06-10 [E]
root@ubu18:~# apt-get update
Get:1 http://repo.localpod/Dml/ldom-debs/ubuntu bionic InRelease [1,154 B]
Err:1 http://repo.localpod/Dml/ldom-debs/ubuntu bionic InRelease
Reading package lists... Done
W: GPG error: http://repo.localpod/Dml/ldom-debs/ubuntu bionic InRelease: The following signatures were invalid: ADE541A20ACF8997C01BDCF7090678A30132048A
E: The repository 'http://repo.localpod/Dml/ldom-debs/ubuntu bionic InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Any clue as to that I am missing, would be welcome... Thanks,
/holger
workaround:
I ended up following a guide ( https://www.digitalocean.com/community/tutorials/how-to-use-reprepro-for-a-secure-package-repository-on-ubuntu-14-04 ) ----> more or less. ---> still a bit 'work in progress', but here are some hints:
using a (fresh) docker image:
docker run -it -v /your/packages:/debs ubuntu:18.04
apt update
apt install -y vim inetutils-ping curl wget netcat telnet aptitude man manpages bash-completion rng-tools reprepro iproute2
rebuild your packages:
cd /debs/src
ls -d */DEBIAN | xargs -n1 dirname | xargs -n1 dpkg-deb -vD --build
time for key stuff. to use an existing key :
gpg --import /debs/.../secring.gpg
for a new key:
gpg --full-generate-key
#rsa 4
#bits 4096
#your_key_name
#passphrase
gpg --edit-key your_key_name
#addkey
#(4) RSA (sign only)
#4096
#0
#yes
#yes
#save
gpg --list-secret
gpg --list-key
gpg --export .....your..key.....number............... > keyfile
apt-key add keyfile
ok, time for reprepro setup:
mkdir /debs/u18repo
cd /debs/u18repo
cat <<END >conf/options
ask-passphrase
END
cat <<END >conf/distributions
Codename: bionic
Components: main
Architectures: amd64
SignWith: .....your..key.....number...............
END
reprepro -b /debs/u18repo includedeb bionic /debs/src/*.deb
to test:
apt-key add keyfile
echo "deb file:////debs/u18repo/ bionic main" >> "/etc/apt/sources.list"
apt update
now, if you share /debs/u18repo on your clients ( httpd ), and import the key with : apt-key add http:/.../keyfile apt update should work...
