I've got no wifi with my newly installed Ubuntu dual booted with Windows.
I'm new to Linux, and so I'm looking for a straightforward way to fix it. Please guide me through steps needed to find and solve the problem. Thanks.
sudo lshw -class network
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: enp2s0
   version: 10
   serial: 08:62:66:dc:91:94
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168g-3_0.0.1 04/23/13 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
   resources: irq:47 ioport:e000(size=256) memory:f7204000-f7204fff memory:f7200000-f7203fff
*-network UNCLAIMED
   description: Network controller
   product: BCM43142 802.11b/g/n
   vendor: Broadcom Corporation
   physical id: 0
   bus info: pci@0000:03:00.0
   version: 01
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list
   configuration: latency=0
   resources: memory:f7100000-f7107fff
rfkill list all
rfkill list all
0: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
Sajad
Try this
Connect to LAN
  1. Search for Additional Drivers
  2. See if there are any Broadcom drivers available( Wait for some time if not available, it takes time to load available drivers some time )
  3. If it already says, Using BroadCom Corporation .., click on 'donot use this device'-> Apply Changes, then again 'Use BroadCom Corporation...'-> Apply Changes
  4. Restart your Ubuntu
you may try to disable 'secure boot' from the bios setup.
https://bugs.launchpad.net/ubuntu/+source/bcmwl/+bug/1572659
and then, if needed sudo apt-get install bcwm-kernel-source
Pilot6
  • 92,041
cmak.fr
  • 8,976
