For some need I have to install php5.3 on my Ubuntu 16.04 system. I have installed PHP 5.3 from ppp:ondraj/php5. I have installed Apache 2.2. But while running apt-get install libapache2-mod-php5 it is showing:
ca-certificates : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
fontconfig : PreDepends: dpkg (>= 1.16.1)
Depends: fontconfig-config but it is not going to be installed
irqbalance : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
libapache2-mod-php5 : Depends: apache2-mpm-prefork (> 2.0.52) but it is not going to be installed or
apache2-mpm-itk but it is not going to be installed
Depends: apache2.2-common but it is not going to be installed
Depends: php5-common (= 5.3.10-1ubuntu3.26) but it is not going to be installed
Depends: ucf but it is not going to be installed
Recommends: php5-cli but it is not going to be installed
libblkid1 : Depends: libuuid1 (>= 2.16) but it is not going to be installed
libfontconfig1 : Depends: fontconfig-config (= 2.11.94-0ubuntu1.1) but it is not going to be installed
libqt5svg5 : PreDepends: dpkg (>= 1.15.6~)
Depends: libqt5widgets5 (>= 5.3.0) but it is not going to be installed
libsasl2-modules:i386 : Depends: libssl1.0.0:i386 (>= 1.0.0) but it is not going to be installed
libsm6 : Depends: libuuid1 (>= 2.16) but it is not going to be installed
libsm6:i386 : Depends: libuuid1:i386 (>= 2.16) but it is not going to be installed
libssl1.0.0 : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
libssl1.1 : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
linux-sound-base : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
locales : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
memtest86+ : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
monodoc-http : Depends: mono-xsp4 but it is not going to be installed or
mono-apache-server4 but it is not going to be installed or
mono-fastcgi-server4 but it is not going to be installed
tzdata : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
wamerican : Depends: debconf (>= 0.5) but it is not going to be installed or
debconf-2.0
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I tried ppa-purge ppa:ondraj/php5 but the problem is same.
I tried to install from .deb source. Here is the output:
Selecting previously unselected package libapache2-mod-php5.
(Reading database ... 301538 files and directories currently installed.)
Preparing to unpack .../libapache2-mod-php5_5.5.9+dfsg-1ubuntu4.25_amd64.deb ...
Unpacking libapache2-mod-php5 (5.5.9+dfsg-1ubuntu4.25) ...
dpkg: dependency problems prevent configuration of libapache2-mod-php5:
libapache2-mod-php5 depends on apache2-api-20120211; however:
Package apache2-api-20120211 is not installed.
libapache2-mod-php5 depends on apache2 (>= 2.4); however:
Version of apache2 on system is 2.2.22-1ubuntu1.11.
Version of apache2 on system, provided by apache2-mpm-prefork:amd64, is <none>.
libapache2-mod-php5 depends on php5-common (= 5.5.9+dfsg-1ubuntu4.25); however:
Version of php5-common on system is 5.3.10-1ubuntu3.26.
dpkg (1.18.4ubuntu1.4) breaks libapache2-mod-php5 (<< 5.6.4+dfsg-3~) and is installed.
Version of libapache2-mod-php5 to be configured is 5.5.9+dfsg-1ubuntu4.25.
dpkg: error processing package libapache2-mod-php5 (--install):
dependency problems - leaving unconfigured
libapache2-mod-php5
Is there any way I can solve the problem? I really need to use PHP 5.3.
