Currently using Ubuntu 18.04, and my wireless driver is not being detected.
I've included a wireless diagnosis log.
$ dmesg | grep iwl
[    6.212724] Loading modules backported from iwlwifi
[    6.212724] iwlwifi-stack-public:master:6988:0d8892f2
[    6.224583] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    6.229811] iwlwifi 0000:00:14.3: Direct firmware load for iwl-dbg-cfg.ini failed with error -2
[    6.230540] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-39.ucode failed with error -2
[    6.230547] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-38.ucode failed with error -2
[    6.230552] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-37.ucode failed with error -2
[    6.230557] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-36.ucode failed with error -2
[    6.230562] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-9000-pu-b0-jf-b0-35.ucode failed with error -2
[    6.236670] iwlwifi 0000:00:14.3: loaded firmware version 34.0.0 op_mode iwlmvm
[    6.248314] iwlwifi 0000:00:14.3: Detected Intel(R) Dual Band Wireless AC 9560, REV=0x318
[    7.264081] iwlwifi 0000:00:14.3: SecBoot CPU1 Status: 0x3, CPU2 Status: 0x2477
[    7.264084] iwlwifi 0000:00:14.3: Failed to start INIT ucode: -110
[    7.276165] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110
sudo modprobe iwlwifi returns no output.
anonymous2
  • 4,325
I noticed this morning that Update Manager installed a later version of the package linux-firmware. I suggest that you obtain a temporary internet connection by ethernet, tethered or whatever means possible and open a terminal and do:
sudo apt update
sudo apt upgrade
I suspect that linux-firmware will be upgraded. After the upgrade, my firmware files include:
iwlwifi-9000-pu-b0-jf-b0-33.ucode
iwlwifi-9000-pu-b0-jf-b0-34.ucode
Reboot so that -38 loads instead of -34 as before. Check the log:
dmesg | grep iwl
Is the alarming message gone?
Your wireless should be working now.
chili555
  • 61,330
Someone I know had her Intel AC Wireless 9560 stop working randomly during the day (Ubuntu 18.04.2). After investigating the dmesg output, checking out the NetworkManager service, reinstalling linux-firmware, rebooting, etc., we tried loading up Windows 10 on the second partition. Even Windows 10 could not find the wireless.
I've seen a few forums mentioning this particular Intel wireless card model. While this may be unhelpful, it's possible your card is broken; you may want to invest in a usb wifi or use ethernet and see if the card can be replaced (or do it yourself) [with another model].
She updated the BIOS and it started working again.
Eliah Kagan
  • 119,640
NuclearPeon
  • 446
I think found a possible fix for it by opening Asus laptop and removing and reinserting Wifi Card did the job for me. I found it under SSD. worth giving a try if you are facing issue with both Bluetooth and Wifi. Old problem but still a nightmare.
-1
  1. You should be sure then your HW support this stuff. It requires the newest HW.
  2. Despite this stuff officially is supported since kernel 4.14+, by the fact you will avoid a lot of issues by using 4.16+ and the newest firmware.
