I'm creating a script to manage my icons and I'm using the command gvfs-set-attribute in order to do that. The script works fine when I run it with the terminal but it fails to work when I use cron. Here is a simplified version of my problem:
#!/bin/bash
PATH=/home/myUser/bin:/home/myUser/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin:/home/myUser/.local/share/gvfs-metadata
gvfs-set-attribute -t string /home/myUser/myFolder metadata::custom-icon file:///home/myUser/myImage.png
I've used crontab -e and settled my script to run every minute * * * * * /home/myUser/script.bash. The problem is that this script doesn't work at all when I run it with cron.
I've already written the PATH on my script as described in this other issue and the output of the command whereis gvfs-set-attribute is:
gvfs-set-attribute: /usr/bin/gvfs-set-attribute /usr/share/man/man1/gvfs-set-attribute.1.gz
So, I'm assuming there's nothing wrong with the PATH here. I've also tried to run my script directly with the absolute path: /usr/bin/gvfs-set-attribute. But any of those things worked... Does anyone have any idea of what's happening and why I can't use the command gvfs-set-attribute with cron?
cron jobs do not run under the X window system, and do not normally access GUI objects.
However, you can cheat.
In a terminal, running under the GUI:
xhost +localhost
echo "export DISPLAY=\"$DISPLAY\"" >$HOME/.display
And, near the beginning of the cron job:
source $HOME/.display
Read man xhost.
waltinator
  • 37,856
Try adding this line to your script (obviously before the call to gvfs-set-attribute):
export $(cat /proc/$(pgrep gnome-session)/environ | grep -z ^DBUS_SESSION_BUS_ADDRESS)
It picks up the DBUS_SESSION_BUS_ADDRESS environment variable from your existing gnome-session. This makes two assumptions though:
  1. You are running a gnome-session; and
  2. There is only one gnome-session
If there are multiple gnome-sessions (i.e. one each for multiple users) you can change this line to work for a specific user by adding the -u option to pgrep. For example:
export $(cat /proc/$(pgrep gnome-session -u myUser)/environ | grep -z ^DBUS_SESSION_BUS_ADDRESS)
If you are not using gnome - then I think this will work with other desktop environments by replacing gnome-session with another value - such as lxsession for LXDE.
