I used to have my PC on Windows and use Putty to forward internet traffic so it would get through my VPS (located in another country) and give me the opportunity to look like I'm located there whenever I needed it. I would connect putty to my server, define a dynamic port forwarding, and then change Firefox settings to use this port as a proxy.
I do not have the slightest idea on how to do this from my fresh Ubuntu install. Can anyone help?
Thanks ahead!
You can set up a socks proxy with ssh command with -D option.
-D [bind_address:]port
[...] allocating a socket to listen to port on the local side, optionally bound to the specified bind_address.
Whenever a connection is made to this port, the connection is forwarded over the secure channel, and the application protocol is then used to determine where to connect to from the remote machine. Currently the SOCKS4 and SOCKS5 protocols are supported, and ssh will act as a SOCKS server.
Example:
ssh -D 8080 username@sshd_server
After that, set the browsers proxy option to use socks5 proxy 127.0.0.1:8080. (via)
pLumo
  • 27,991
