I Have a brand new high speed mSD card perfect for LVM-FullDisk-Encryption. Problem is, Non-Volitile SolidState memory has a finite amount of write cycles that will rapidly decrease at an alarming rate due to SWAP data constantly written to it. FINE! I dont need SWAP space, I'll leave it out of my Table. However I left it thinking my RAM would cover me enough the system might not find it necessary to allocate from there. I figured if I got really worried I can track my memory usage thru SysMonitor but I dont trust it yet, I havent peaked my RAM to see any result other than zero usage. I cant find my swap space, any thoughts? Will I be able to disable my swap without knowing where it is?
Here's some useful CLI commands to help you make sense of what's going on.
The first is the command free which will provide results similar to what you see below:
              total        used        free      shared  buff/cache   available
Mem:        7614996     1855044     3592444      202500     2167508     5197716
Swap:       1048572      594772      453800
As you can see above I have 1048572 bytes of swap reserved on my system and am currently using 594772 bytes of it. the 2167508 bytes of buff/cache makes it plain that I don't have to be using swap and can safely turn it off completely with the command sudo swapoff -a
AS is clearly stated on the man page which you can see if you issue the command man swapoff
swapoff  disables  swapping  on  the specified devices and files.  When the -a flag is given, swapping is disabled on all
       known swap devices and files (as found in /proc/swaps or /etc/fstab).
Having issued the command sudo swapoff -a I can confirm that it's off even though I didn't specify where it was by running free again and the results are:
Mem:        7614996     1978976     3297572      379672     2338448     4905560
Swap:             0           0           0
Edit: Note that to turn swap back on without knowing where it is you can issue the command sudo swapon -a
I believe this concise answer should eliminate any concerns you have about trusting SysMonitor as it doesn't use it, explains how you might find your swap space if you set it up, and how to disable and re-enable it without knowing where it is.
Elder Geek
  • 36,752
