During installation of CUDA 9.2 on my Ubuntu 18.04 desktop machine it reports an error on finding the already installed driver 396.24 I got from PPA. It is trying to install driver 396.26. How can I get rid of the 396.24? I have tried several times using various syntaxes of remove or purge, but I'm obviously not expert enough to get it right.
This is the text of the error message:
Unpacking nvidia-396 (396.26-0ubuntu1) ...
dpkg: error processing archive /var/cuda-repo-9-2-local/./nvidia-396_396.26-0ubuntu1_amd64.deb (--unpack):
 trying to overwrite '/lib/udev/rules.d/71-nvidia.rules', which is also in package nvidia-kernel-common-396 396.24-0ubuntu0~gpu18.04.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Thomas
  • 6,433
DeepExplorer
  • 81
I ran into the same problem, and fixed it by doing this:
  1. Fix the broken package
    sudo dpkg -i --force-overwrite /var/cuda-repo-9-2-local/./nvidia-396_396.26-0ubuntu1_amd64.deb
  2. Reinstall the whole thing while passing the --force-overwrite option to the underlying Dpkg when running the install command (based on this answer)
    sudo apt-get -o Dpkg::Options::="--force-overwrite" install cuda
There was a prerelease build of 396.26 on an ubuntu launchpad.net ppa, and I was able to successfully build and run CUDA 9.2 from that. The package is no longer on that ppa, which belonged to an individual. Hopefully it will get pushed forward.
The Alexabdre Godardn's answer doesn't work for me.
I fix this issue only with this:
sudo apt-get -o Dpkg::Options::="--force-overwrite" install --fix-broken
iamtodor
  • 818
