I addition to being aesthetically pleasing, I am quite pleased with some of the new features in 18.04. However, what I am not quite impressed with is how slow it is recovering from the lock screen. See, on my 8-year-old laptop, every time I open the screen or I come back to it after it locked automatically due to inactivity it takes what I consider to be an extremely long time to recover from a locked screen after typing in my password. Two weeks or so ago I switched to 18.04 (fresh install) on my laptop that was using 16.04. Unlocking the screen on 16.04 took only a second or two while now, on 18.04 it takes 15-20 seconds or so. Once in, everything seems to run as smoothly as usual.
Anyone can tell me how I can check what is causing this?
P.S.: It is likely some people will say that it may have something to do with how many extensions I have running. However, my guess that it should not as there are only two shell extensions running (that I can tell): Ubuntu AppIndicators and Ubuntu Dock.
Update:
As suggested in the first comment, here is the output of journalctl -b. The End looks like this only displaying the last commands corresponding to the time stamp right at the moment I started to unlock the system.
May 28 09:36:56 tm2 org.gnome.Shell.desktop[1342]: Window manager warning: Overwriting existing binding of keysym 73 with keys
May 28 09:36:59 tm2 gdm-password][5500]: gkr-pam: unlocked login keyring
May 28 09:36:59 tm2 gnome-software[1630]: no app for changed ubuntu-dock@ubuntu.com
May 28 09:36:59 tm2 gnome-software[1630]: no app for changed ubuntu-appindicators@ubuntu.com
May 28 09:37:00 tm2 gnome-shell[1342]: [AppIndicatorSupport-DEBUG] Registering StatusNotifierItem :1.61/org/ayatana/Notificati
May 28 09:37:00 tm2 gnome-shell[1342]: [AppIndicatorSupport-DEBUG] Registering StatusNotifierItem :1.56/org/ayatana/Notificati
May 28 09:37:00 tm2 gnome-shell[1342]: [AppIndicatorSupport-FATAL] unable to lookup icon for chrome_app_indicator_1_1
May 28 09:37:01 tm2 gnome-shell[1342]: [AppIndicatorSupport-FATAL] unable to lookup icon for chrome_app_indicator_1_1
May 28 09:37:01 tm2 gnome-shell[1342]: [AppIndicatorSupport-FATAL] unable to lookup icon for chrome_app_indicator_2_8
May 28 09:37:02 tm2 gnome-shell[1342]: [AppIndicatorSupport-FATAL] unable to lookup icon for chrome_app_indicator_2_8
May 28 09:37:06 tm2 org.gnome.Shell.desktop[1342]: Window manager warning: Overwriting existing binding of keysym 73 with keys
May 28 09:37:07 tm2 org.gnome.Shell.desktop[1342]: Window manager warning: Overwriting existing binding of keysym 73 with keys
Unfortunately, I do not know what I am looking for. I note that this time it took about 8 to 10 s to unlock.
Also, I did dmesg | grep error and here is what I see:
[ 5.462658] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro
[ 6.824954] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
In the latter, I do not see anything that could potentially trigger the delay. Mind you though, I do not know how to read the whole output of dmesg.
Update 2:
I am NOT using Wayland as very often when I use it the computer freezes. I only use it when I need to use the overhead projector otherwise I cannot get the second monitor (and the main monitor goes black until I unplug the VGA cable).
One more thing that I noted is that when it takes very long time and I do CTRL + ALT + F1 I go to a terminal message window where I can actually see my password as I typed it as the last line in the output. This is now a very severe security vulnerability issue in my system.
