When my Xubuntu 18.04 laptop resumes from suspend, systemd-logind automatically logs out of the current session if the laptop has stayed suspended for more than a couple of hours. If the interval between suspend and resume is short, it doesn't log out. I still haven't discovered how long this interval has to be in order to cause the logout.
I enabled debug on the systemd-logind.service, creating file /etc/systemd/system/systemd-logind.service.d/10-debug.conf:
[Service]
Environment=SYSTEMD_LOG_LEVEL=debug
which causes systemd-logind to log all D-Bus messages it handles, but couldn't spot anything that might have caused the logout.
I scanned all systemd journal messages (journalctl) before systemd-logind starts killing the current session, investigated all that looked suspicious but couldn't find anything that might influence an automatic logout. Here are some of the messages that striked me as suspicious (they are not sequential, but pulled from different occasions):
upowerd[1600]: unhandled action 'unbind' on /sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0
polkitd(authority=local)[840]: Unregistered Authentication Agent for unix-session:c2 (system bus name :1.46, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
wpa_supplicant[811]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface dbus_property=Stations getter failed
wpa_supplicant[811]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
at-spi-bus-launcher[7031]: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
at-spi-bus-launcher[7031]: after 30333 requests (30333 known processed) with 0 events remaining.
systemd-logind[779]: Inhibitor xfce4-power-manager (xfce4-power-manager handles these events) pid=8611 uid=1000 mode=block stopped
systemd-logind[779]: Electing new display for user paulo
systemd-logind[779]: Ignoring session c8
logind config doesn't have anything that might cause this:
paulo:~$ loginctl show-session
EnableWallMessages=no
NAutoVTs=6
KillUserProcesses=no
RebootToFirmwareSetup=no
IdleHint=no
IdleSinceHint=0
IdleSinceHintMonotonic=0
BlockInhibited=handle-power-key:handle-suspend-key:handle-hibernate-key
DelayInhibited=sleep
InhibitDelayMaxUSec=5s
HandlePowerKey=poweroff
HandleSuspendKey=suspend
HandleHibernateKey=hibernate
HandleLidSwitch=suspend
HandleLidSwitchDocked=ignore
HoldoffTimeoutUSec=30s
IdleAction=ignore
IdleActionUSec=30min
PreparingForShutdown=no
PreparingForSleep=no
Docked=no
RemoveIPC=yes
RuntimeDirectorySize=615313408
InhibitorsMax=8192
NCurrentInhibitors=5
SessionsMax=8192
NCurrentSessions=1
UserTasksMax=10813
I can't find any anything that might cause an automatic logout after a time interval. I'm really stumped.
